EcoModder.com
-   Aerodynamics (https://ecomodder.com/forum/aerodynamics.html)
-   -   do ventilation intakes add to drag? (https://ecomodder.com/forum/showthread.php/do-ventilation-intakes-add-drag-13358.html)
lunarhighway 05-25-2010 03:51 PM
i'm talking about the vents in front of the windshield.
my reason for asking as that i recently noticed on my car the intakes are in an odd location. the car's hood kicks up a bit near the windsield and thus forms a bit of a recess where the wipers sit = good. however the actual intakes are locates at the outer edges near the a pillars, and the plastic covers actually show these intakes being ducted to the center where the ventilation fan motor is.
this seems a bit odd as i would assume that the high pressure bubble is strongest at the center/base of the windshield and not near the sides at the A-pillars where the air accelerates to move around the car. Also the fact that the intakes and ducts are the same piece of plastic, just changing the locations of the holes would do the job (and drilling or cutting holes would still do).
why this bothers me is that i have to run the fan most of the time to get some air in the car while my previous car had the intakes where i think they should be, and ventilation was much better.
any thoughts on this?
Arragonis 05-25-2010 10:27 PM
Does the car have pollen filters and if so have they been changed when they should ?
Piwoslaw 05-26-2010 03:24 AM
Same here: ventilation intakes on the sides, hidden under the hood. No air without fan:(
I think moving it to the center won't help much since it'll still be under the trailing edge of the hood which helps hide the wipers.
I think there are only two ways to get forced air into the cabin: either a duct from the high-pressure bubble ahead of the car, or air scoops a la Peugeot 206. Though my Dad-in-law had a P206 and I remember that the fan also had to be on all the time.
lunarhighway 05-26-2010 03:40 AM
As far as i know it has no such filter, it's an older car originally designed in 1988 and mines a 1995 model when the line ended but basically not much changed. It could be the ventilation is more restrictive internally than my previous car... that was a 1985 opel kadett and after it was parked under a tree for quite a while bits of leaf would blow out of the vents :D None of that on this car fortunately, so perhaps there is some sort of filter internally. The fan looks like some kind of hamster wheel so that should make for some restriction too when it's not turning... Still when you design a more restrictive ventilation system wouldn't it be logic to try and tap into the ram effect even more to compensate?
lunarhighway 05-26-2010 04:15 AM
some previous mercedes models and some other cars i've seen have a grill in the hood just ahead of the windshield before the wiper recess that if i recall correct is ducted to the ventilation.
maybe with modern climate controle and filters natural airflow has become less important, but since i'm running the fan a lot i'm looking for ways to reduce my electrical load (as long as that dousn't bring any new drag)
vtec-e 05-26-2010 04:29 AM
Originally Posted by Piwoslaw (Post 176206)
...........or air scoops a la Peugeot 206. Though my Dad-in-law had a P206 and I remember that the fan also had to be on all the time.
Had one myself. Same problem. I tried to resolve it by removing part of the ductwork under the scoops. I think it was to help keep rain out of the pollen filter but i tried it anyway. Definitely helped airflow into the cabin but it was a bit noisy and kind of howled as i got up to motorway speeds.
ollie
tollo 05-26-2010 07:14 AM
I think that biggest reason why we need more fan, is that air can't find its way to out.
Old VW beatle was dense like mordern cars. (Beatle could float on the water pretty long time) Heater couldn't blow the air from back of the car to cabin. It was needed to add also air outlet to back of the car. I think that same thing would help with modern cars. Easy way to test this theory is to open window littlebit and you get much bigger flow.
Beatle also needet thermal insulation to inflowline to get cabin warmer.
I think that you can't get measureable gains to FE by changing the intake place. Outlet place is more importan. Same thing with cd: You can get more gains from back off the car than from front.
This is just my point of wiev. :)
texanidiot25 05-26-2010 01:57 PM
Modern cars just aren't designed to flow air that way through the cowl, that's what they designed A/C for. My '69 Chevy has vents in the kicker panels that open up to circulate air low in the cab, as well as through the vents, and the vent windows which move awesome amounts of air. New cars aren't designed to take advantage of this now days, and I'd asume the recessed cowl vents under the hood have a large part of this too.
basjoos 09-29-2014 10:14 AM
One thing I noticed was that as I added aeromods to reduce my car's Cd, the non fan assisted air flow also got progressively less as I reduced the front high pressure/rear low pressure differential that drives air flow through the vents in most cars. So, in an ultra-low Cd car, is it more efficient to run the vent's electric fan (with its attendant alternator load) to provide cabin ventilation or is it better to accept the added drag of a vent scoop on the hood or windshield to move air through the cabin.
JRMichler 09-29-2014 01:17 PM
I used to own a 1968 Volvo 144. That car had the air intake in the center at the base of the hood. The air flowed around a baffle, down over the blower motor, and down through the heater core. When parked, snow would find its way into the motor and onto the heater core. The motor was an open motor, with the bearings and windings directly exposed to the snow.
When the engine started to warm up, the snow would melt, and the defroster was a window fogger until the heater core dried out. And the moisture destroyed the blower motor. And it was an eight hour job to replace the motor.
I finally got tired of the problems, so removed the heater blower, sealed the cowl opening, made a fiberglass duct from the cowl through the engine compartment, and installed a GM heater blower in front of the radiator. The heater blower had the inlet facing to the rear.
Since the heater blower inlet was in a high pressure area, I did not need to run the blower at highway speeds. Since the blower was far away, I could not hear it on low, and could barely hear anything on high. And zero problems with rain or snow.
Sometimes, I'm tempted to do something similar to my Canyon to reduce electrical load.
