Do you smell a scam?
4 Attachment(s)
If you have ever looked up getting better MPG I'm sure you have seen these things, do you think they are a scam? Supposedly you stick them in your intake & they spin the air & that will for some reason give you better MPG. Some of the testimonies on these things report +1MPG, +4 MPG, +40% MPG exc. I think its bull, but for $30 it would be worth it if they did work...http://ecomodder.com/forum/attachmen...1&d=1243580607 http://ecomodder.com/forum/attachmen...1&d=1243580607 http://ecomodder.com/forum/attachmen...1&d=1243580607 http://ecomodder.com/forum/attachmen...1&d=1243580607
Typing "tornado" into the search box might be enlightening
A block of wood under the gas pedal would give about the same results - permanent restriction. If you want that, the extra mixing from this rig might be worth a couple of bucks in improved mileage.
Bob- extra mixing? improved mileage? Seriously??? :confused:
Smokey Yunick was a strong proponent of aids to evaporation of the fuel, so this gadget might help that way. Especially if it was downstream from a dirty injector. However, I wouldn't take the time to install one even if my dad gave it to me.
That is true. His was basically a turbo wasn't it? With no intercooler and running real hot?
If I'm not mistaken these tornados and whatnot install AHEAD of the throttle body and ahead of any fuel. The throttle plate will mess up whatever it is they are purported to do anyway. |
Yeah, Smokey's intake temp was getting up to 450 F, AFAIR. No carb icing on his rig. :-)
Gosh, the old J.C. Whitney "turbo" spinners were supposed to go between the carb and manifold. Maybe the suckers are even dumber now. |
My question would be: clockwise or anti-clockwise, which is better?
Put any one of these gadgets in Google and look 2 or 3 pages in.
You will find lawsuits and false advertising litigation abounds. All of these type of "Fuel Atomizers" have been tested by the EPA and found to do nothing at best and waste fuel while restricting your air flow at worst. |
Same effect as most HAI. It reduces the amount of power you have and therefor automatically makes you drive more eco friendly just because. . .well you can't do anything else.
It's like bob said, if you stick a really big block of wood under your gas pedal its just as eco friendly. It keeps you from using fuel. Does not in anyway actaully improve efficiency just reduces driver waste at best. The gains will be minimal if anything because you are inducing extra restriction and therefore pumping losses on the engine. |
lol Frank thats a myth. The swirl direction comes from the suction pattern and the flow pattern.
If you take a pump and drain water out the bottom of a barrell and inject the water back in at the top the direction of swirl is determined by(if the pump has a face, that) the direction the water is added. If you notice water pours into the bowl itself in one direction usually Also the water coming through that wide mouth hole at the bottom front of the bowl is swirling in that direction as well. Toilets that don't swirl at all(large powerful commercial toilets) suck water straight down no vortex whatsoever. I worked at a summer camp and we got sick of pumping toilets daily so we got the massive suction versions. They don't swirl at all and you had best standback. . |
I like those toilets that make you hang onto the rails to avoid being sucked in. They're the only ones that can handle what I leave in them in one shot!
I know that's disgusting, but I couldn't resist. |
Those tornado things look like a shrapnel accident waiting to happen.
scam
No science-talk here,but even if the restriction in the intake did not INCREASE pumping-losses,would not any of this "beneficial turbulence" be nullified as soon as the air passed through the throttle-body or carburetor throttle-plate.And in a carbureted engine,which can have significant droplets of fuel present in the charge,would not the centrifugal force of a vortex not behave as a cyclone-precipitator,slinging the fuel to the walls of the intake runners,wetting out the walls? I'm given to understand that turbulence can be great for induction however,"vorticity" is a completely different animal.
lol aero,
I just assumed it had to go in after the throttle otherwise it would be pointless. Yeah apparently whoever thought of this had not heard of a lab centrifuge -_- |
