Does a windshield help with a bike's aero?
At highway speeds regarding mpg, in a full upright ride posture and at what point is a windscreen too big for mpg improvement? I am not including any weather riding/comfort improvements that a windscreen might provide.
Scanned 5? pages, didn't see this topic addressed. |
Depends on the shape. Full upright would be worst, compared with semi-recumbent or cafe racer crouch.
I don't know that any windscreen is more efficient than just the rider. Unless you're ducking in the little bubble of a sport bike, I don't think they add any aero improvement and are entirely for comfort purposes.
I had a cracked windscreen completely break away at full throttle on the CB750, and I want to say I gained another 10 MPH of top speed after that. It was making that big of a difference in drag. |
The folk wisdom on the Salt Flats is that it's not how you make the hole, it's how you close the hole.
http://2.bp.blogspot.com/_X_tJstZ1fV...1600/spuik.jpg 2.bp.blogspot.com/_X_tJstZ1fVE/TRILN62i6xI/AAAAAAAAAHk/-h906_09Phw/s1600/spuik.jpg Were I to expose myself without a cage, I'd want a teadrop helmet with Bluetooth and internal rear-view cameras, an airbag vest in a backpack, and a tailbox. Maybe a bug deflector? |
Kevlar neck gaiter? :)
I just don't see how a windscreen is likely to increase efficiency, because to provide comfort to the rider it must necessarily increase frontal area beyond the exact dimensions of the rider.
A windscreen that doesn't increase frontal area by definition would have to be smaller than the rider. What's the point of a windscreen that doesn't prevent wind from hitting the rider? I doubt I'd notice a difference in a tuck on my bike with the windscreen there or not. Maybe my chin would be spared the feeling of a strong man shoving my head backwards. Only advice I have is to try the Julian method of throttle blocking to test the various top speeds at a given throttle opening on a given stretch of road. My guess is the bigger the windscreen, the slower you go, which is why sportbikes have windscreens that look like this. https://www.motorcycledaily.com/wp-c...daf4iside2.jpg If you rest your chin on the tank, your eyes will finally peer out through the windscreen, and the top of your head will still stick above it. https://resources.stuff.co.nz/conten...5989458428.jpg The problem isn't the bike, it's the rider. |
Im old enough to remember Craig Vetters early efficiency wrap around fairings for Honda 750's They were pretty good at increasing bike speed and bug deflection
