Old 02-08-2009, 11:37 PM   #1 (permalink)
Grease Car Named Desire
2003 Golf SVO Nozzles
Anyone know the #'s ( true hole size) & angle of nozzles recommended for SVO in a 1.9l Golf TDI automatic?
Old 02-09-2009, 08:04 AM   #2 (permalink)
tasdrouille's Avatar
The Guzzler - '08 Hyundai Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '11 Kia Soul 2U
What are you concerned about? Stock size is fine. Since you have an auto with an 11mm pump head, your nozzles are .158. You could go to .184 (stock 5sp size), but that would not help economy without tuning.
www.HyperKilometreur.com - Quand chaque goutte compte...
Old 02-09-2009, 04:27 PM   #3 (permalink)
Other sites state there is a issue with stock nozzles spray angle + VO resulting in deposits on far cly. wall / rings & Elsbett (sp?) of Germany claims to have 'specially made' nozzles for their kits. While most problems should be moot with preheating injectors to 190*F, there is human error lurking out there & mechanical goodies do fail, so I would like to have nozzles better 'tuned' for VO.
Is this just a dream or are VO nozzles available? Or is this not a major issue.
Old 02-09-2009, 04:59 PM   #4 (permalink)
I am unaware of "VO" nozzles. With stock nozzles the spray angle makes it so fuel is sprayed into the piston bowl, right at the bowl's lip, so fuel is never directly sprayed towards the walls.
What can happen though is that since VO is more viscous, it will form bigger droplets than USLD. If the droplets are too big, the fuel might not all burn and you will get deposits on exhaust valves along with crankcase oil dilution. If anything, bigger holes will just make bigger droplets.
Just make sure you heat the VO properly, be anal about your system, and you'll be fine with stock nozzles.
Old 02-09-2009, 06:32 PM   #5 (permalink)
Thanks Tasd.
That agrees with my research.
I think some folk want us to believe in their 'magic' to sell parts.
News: VW to unveil 70 mpg (US) Golf diesel hybrid MetroMPG Hybrids 27 06-29-2010 07:50 AM
2003 Toyota RAV4 Electric Vehicle cfg83 For Sale 15 01-09-2009 07:27 PM
Injector nozzles tasdrouille General Efficiency Discussion 4 12-28-2008 10:11 PM
Golf cart comparison at 17 MPH offroad1994 Fossil Fuel Free 1 07-06-2008 11:21 PM
