EcoModder.com
-   Aerodynamics (https://ecomodder.com/forum/aerodynamics.html)
-   -   Drag per aft-body length/roof angle (https://ecomodder.com/forum/showthread.php/drag-per-aft-body-length-roof-angle-27922.html)
aerohead 01-07-2014 06:06 PM
There is still discussion about proper 'angles' for roof down-slope,for achieving the optimum drag reduction.
I expanded upon a drag table Hucho published in his 2nd-Edition book,based upon Rolf Buchheim and his associates research findings published in 1981.
As you can see,the best angle depends upon the length of the vehicle's aft-body,as a percentage of the vehicle's total length.
In the 5-illustrations,each image denotes the the angle which produces the lowest drag for its particular aft-body percentage.The original test model,with no roof angle is taken at an estimated Cd 0.50.
If the angle is either steeper,or more shallow,the drag will increase.
NOTE: These values are only for a vehicle with absolutely zero roof camber.Just a perfectly flat roof,as with JEEP Wrangler,HUMMER H-1,etc..
http://i1271.photobucket.com/albums/.../scan01-07.jpg
Here are the values I came up with for Xist's comparison:
http://i1271.photobucket.com/albums/.../Scan01-11.jpg
Since some of the members are considering angled tails,I'll throw in a couple tables from the boat-tailer trailer thread:
http://i1271.photobucket.com/albums/...ead2/Scan4.jpg
Here's one which factors in edge radii as well:
http://i1271.photobucket.com/albums/...ead2/Scan1.jpg
Here id W.A.Mair's boat-tail architecture recommendation:
http://i1271.photobucket.com/albums/...ad2/WAMair.jpg
Here are some wing section drag comparisons which emphasize the importance of the aft-body :
http://i1271.photobucket.com/albums/...head2/8-24.jpg
Here is a drag table illustrating the actual drag coefficient for the wake of a half-body -based vehicle,at varying degrees of aft-body truncation:
http://i1271.photobucket.com/albums/...d2/8-3-133.jpg
You can see the truncation effect illustrated here with the Daimler-Benz,Mercedes-Benz,1978 C-111 III record speed/fuel economy experimental car:
http://i1271.photobucket.com/albums/...rawings1-1.jpg
This table illustrates the "sweet-spot" for elliptical bodies of revolution,who's Cds are shared by streamline bodies of revolution of the same fineness ratio.Your car,and it's mirror-image below the ground define it's "effective" fineness ratio.:
http://i1271.photobucket.com/albums/.../Untitled1.jpg
This table illustrates the "sweet-spot" for streamline bodies of revolution which Hucho recommends we use,along with wing-derived bodies for the absolute lowest drag.You'll notice that the longest,and the shortest share the highest drag,and the Cd 0.029 represents the drag minimum.This specific form is essentially the Aerodynamic Streamlining Template.It has the lowest drag while still respecting the 22-degree aft-body slope needed to prevent separation.:
http://i1271.photobucket.com/albums/.../drawings2.jpg
Here is a drag table for symmetrical wing sections of 2-D flow illustrating the "sweet-spot" for low drag.This center image has the lowest drag,and it's aft-body fineness ratio contour has shown up on many of the lowest drag vehicles ever measured.And it is what I recommend for use in plan-taper of any boat-tailing:
http://i1271.photobucket.com/albums/...rohead2/-2.jpg
Here is a schematic of the underside of the Aerodynamic Streamlining Template,roughly utilizing the contour of the minimum drag symmetrical wing section.
http://i1271.photobucket.com/albums/...ad2/Bottom.jpg
Here is a side elevation of the AST-II to help understand the belly image above:
http://i1271.photobucket.com/albums/...ad2/Scan12.jpg
Here is table #14,which is derived from Hucho and associates,with their wind tunnel work on the Golf/Rabbit,Scirocco,and Polo,published in their SAE Paper # 760185,from 1976.
I could not find a true-length image of the Polo for which Hucho's original table showed in a vignette,so I've shown a Golf-1 which would have behaved similarly.
As you'll see,with optimized nose,edge radii,roof camber,vertical and body side camber,and tumblehome,the drag reaction to the rear slope angle behaves quite differently from the rudimentary and primitive models investigated by Bucheim et al.
NOTE: In this SAE Paper,Hucho mentions that beyond 23-degrees,the wake transitions to a squareback wake,and there is a critical range of angles at which the wake will alternately jump back and forth between a fastback wake and squareback,leading to exceptionally high drag.At about 38-degrees,the squareback wake is firmly established,and any further steepening of the slope has no affect at all on the drag.
W.A.Mair determined that 22-degrees is the critical angle not to exceed.Which is in close agreement with Hucho.
http://i1271.photobucket.com/albums/...an01-18-14.jpg
Here is a link to a current image from Mercedes-Benz.The bottom green line behind the roof depicts a 'surface' the air might like to see:
http://asset4.www5.mercedes-benz.com...im_Quadrat.jpg
Here is another image from the same site,illustrating what boat-tailing the aft-body will eliminate:
https://www.google.com/search?q=aero...F%3B1230%3B454
Here is an image of a very simple wind tunnel model :
http://i1.ytimg.com/vi/nrqwltq83FQ/hqdefault.jpg
Here is a NASA image of notchback drag
http://www.nasa.gov/images/content/4...5-012_full.jpg
ennored 01-07-2014 09:49 PM
Interesting! Makes me think about my flat sided and flat roof RV. And why something like a trailer tail works, but doesn't follow the template.
To be clear:
Only the roof is changed? (No plan taper)
The dashed line represents the template? (Like to see these drawn in 3D with round ("body of revolution" - clear?) superimposed)
And a question:
Think a curved surface (in side view) in place of each the "slashed" surface could do better? (easy answer being "yes", hard answer being what it looks like?)
redyaris 01-07-2014 09:57 PM
The 4th edition of aerodynamics of road vehicles by Hucho, does not have fig. 4.59.
One of the things I am working on this winter is the rear head rest fairing on my Honda VT500. I would like to determin what would be the best angle of the slope but can not find anything specific, so I will need to do some tuft testing to find out...
best regards
kach22i 01-08-2014 07:58 AM
Interesting cut-sheet / figures.
I'm still trying to figure out how this can be applied to an existing car without cutting it all up though.
The numbers are all much higher than I would have imagined based on the dramatic profile differences.
aerohead 01-08-2014 05:31 PM
To be clear
To be clear:
And a question:
*Yes,only the roofline is altered.
*Zero body side camber
*Zero plan taper
*yes,the dashed line is the faster version of the 'Template'.
*Buchheim offers a drag table for 'curved' rooflines of which the 'optimized',lowest drag configuration includes an up-kick rear spoiler.As perverted as I am,I could make no quantitative assessment of it based upon the limited information Buchheim provided.There's just no way to compare it to anything else.
*What Buchheim shows,is a fastback,who's roofline curves down into a maximum 27.5-degree slope of which the upper tip of the spoiler creates a 21-degree backlight-to-'boot' angle,terminating at 31% of the 'Template'.
Buchheim states that this 'optimum' angle is highly dependent upon the C-Pillar design.(so maybe he was reluctant to assign numbers since he could not represent the 3-D nature of the C-Pillar.)
As to Trailer-Tail,I think that AT Dynamics is working with something optimized for the arbitrary length limitation imposed by the USDOT,and also,creating something the drivers are willing to put up with.
I take dinner near the interstate each week and can tell you that a lot of the Mesilla Valley Trucking Co. rigs are going by with the Trailer-Tails folded and stowed.I don't know why this is so.
aerohead 01-08-2014 05:40 PM
turtledeck
best regards
I'd be inclined to mimic something like the architecture of the VARNA Diablo.The university team members I visited with analyzed VARNA and gave it Cd 0.11.So
'Georgi' couldn't have done too bad with it.
aerohead 01-08-2014 05:44 PM
applied
Bear in mind that there aren't any passenger cars constructed with such simple straight body elements.
And if a project car has any curvature at all,then none of these angles and values apply.
Xist 01-08-2014 08:48 PM
Okay,https://scontent-a-dfw.xx.fbcdn.net/...87566057_n.jpg
beluga 01-08-2014 09:30 PM
re: un-used trailer-tails
Perhaps because the drivers/warehouse workers don't understand the utility of them, are not compensated extra for using them, and it represents make-work to them since they're not paying the gas bill. Unless the drivers are contractors, in which case they would use them if they knew they'd save money...
Lack of training?
beluga 01-08-2014 09:35 PM
increased MPG w/o chopping your roof...
Don't chop your roof. Build it up.
To create the "whale" type roofline by adding a roundish roof on top of flat cars, like mine is, might improve airflow dynamics.
In addition this helps improve kammback performance, and is linked to it.
Two issues.
1. how to construct the dome roof using what materials
2. adding any height increases CdA
3. does making the car more like a teardrop/plane wing improve MPG more than it hurts it from bigger frontal drag area?
The slope we want:
http://brightmindsinstitute.com/imag...108_093628.jpg
The slope I have:
http://brightmindsinstitute.com/imag...108_093007.jpg
Proposed "solution", if it makes sense... my mouse skill isn't great and the mouse skips around. I'd want a lower profile "whale roof."
http://brightmindsinstitute.com/imag...modder.com.jpg
