Drag reduction modifications in wind tunnel: Audi A2 from Cd 0.288 to 0.204
1 Attachment(s)
Hi,
Thanks to Ausias who tipped me off with this Cd study: http://wwwm.coventry.ac.uk/researchn...%20Vehicle.pdf Lupos 0.25 Cd target starts to feel pretty plausible without chopping the roof ;). Enjoy. ---- SUMMARY... (added by MetroMPG, because these online files have a bad habit of disappearing...)
0.25
Awesome paper. Makes it easier to quantify every mod accordingly.
Good simple paper to guide mods. I'm a wind tunnel engineer at work and like seeing studies like this with measured data.
Thanks for sharing. :D |
I had seen mention of the " box cavity" method of reducing drag at the rear in an old paper* from the UCDavis " future car " hybrid Ford Taurus .
It's good to see results quantified here . * no longer online. |
Vekke - nice find! I added the summary to post #1, since these files often disappear from the web after a while.
If you notice the caption on the bottom of the picture of the A2 at the top of the paper, there is mention of the A2 being introduced at .25 Cd .
This number is often given as the official Cd in published literature ( I've also seen .27 ) This makes me wonder what would have caused such a drastic rise in drag to .288 . The only visible changes are the style of wheels, and surely this would only account for a count or two . ( And it also makes me wonder if they did the same mods to the .25 version, just how low of a Cd they would have achieved ! ) |
Ride height is one mod our experimenters didn't attempt here. |
Too bad those slides didn't give more info about the effects of the rear box cavity versions.
145/80R14 tires Lower ground clearance smooth hubcaps almost fully blocked front grille smooth underside to some extent plus lots of small modifications Lupo 3L has smaller mirrors I am not sure if A2 has them on also |
More interesting info ..
This was just one presentation from the "The Aerodynamics Challenge Dissemination Event on 19 October 2011"
Some more presentation can be found here : Coventry University - The Aerodynamics Challenge |
I have often wondered if there is a "synergy" effect when combining different drag reduction mods. Would there be a perfect combination ?
Thanks so much for sharing . Is any of this presentation available on YouTube or elsewhere as a video ? I would have loved to hear what the speakers had to say . |
...this presentation (aft body taper) looks interesting too: http://wwwm.coventry.ac.uk/researchn...ple%20body.pdf
...and, here's Jaguar info on wheel design: http://wwwm.coventry.ac.uk/researchn...l%20Design.pdf |
Lots of useful data which need lot of thinking to be able to use that when engineering/making parts. I liked those moving wheels, because I had one similar idea that was there also.
So is their 2 inch concave tail section showing me I should fit the skin 2 inches long to form a concave at the back of the Kammed off tail I am building for my Vetter style motorcycle?
On a motorcycle, your Cd is basically just a raw factor of your frontal area. That's why a recumbent riding position is one of the most effective ways to bite a chunk off your fuel consumption. As long as your fairing is rigid in the wind, your mpg will kick butt. The rear back inches of the Audi fairing would end up being negligible on a motorcycle when compared to weight gain/frontal Cd. Good luck with your motorcycle, sendler. We'll all love to see what you'll come up with! |
This led to their excessive price and the weak market response. |
Closing the gap is easy, making it actually work is something else again. ;) What they didn't do is fit covers on the insides of the wheel, or easier, fit a vertical blanking plate "fencing off" the inside wheel cavity. This would need to fit close to the wheel, and be fitted on the suspension so it moves along with the wheel. |
What is even more surprising is the fact that the 2° diffusor helps.
On this kind of station-wagon-like rear ends - no diffusor at all ( 0° ) was found to offer the lowest drag, with a cavity, the diffusor helps another 6%. A rear cavity is something that I could easily fit on Hägar. A bit of foam and double-sided tape will do. |
With addition of rear cavity it is more like boxed from rear. Before cavity they used 7 degree diffusor, but with cavity 2 degrees was optimal, so if I'm not horribly misreading that would also tell that they did move from coupe/hatchback to boxed end, however it is much smaller boxed end. High side window line and blunt front are perhaps what makes illusion of car being box shaped, sides are also rather straight down and it is relatively tall compared to width, but if one photoshops everything under window line away it is not boxed station wagon shape at all and what affect to diffuser angle is how upper side, roof, trunk lid etc are angled from top, afaik. This should make it easier to see how it is not station wagon kind of shape at all (extract from document mentioned in 1st post): http://jtbo.pp.fi/images/road_pics/A2_roof.jpg That is one of the pits easy to fall with aeromodding, they use lot of tricks with cars that cheat eye, to see true shape and form sometimes one needs to take photo and edit it a bit. |
The box cavity should be an easy mod on a square-backed wagon though. It won't be as efficient without a bellypan though. |
http://ecomodder.com/forum/showthrea...tml#post296642 Most of such examples were made at time when wagons were truly boxed shape, so that is why wagon is shown to have 0 degrees at optimal diffuser angle, but it might mislead modder to think that all wagons should have that as new stuff indeed has angle, so it can't be true anymore with all wagons. So when one puts on boxed cavity to rear, one need to put diffuser, that is closer to 0 degrees, but without boxed cavity diffuser must be more angled if roofline drops, when roofline does not drop 0 degrees is best, how about boxed cavity on boxed rear end without dropping roofline? I guess 0 degrees still? This leads to thinking that boxed cavity turns dropping roofline to be more towards boxed shape, but as it makes it smaller boxed shape it will be improvement to efficiency. Or something like that. Most important to know would be just that there are no absolutes and it is impossible to generalize, every situation must be examined separately, but understanding why some forms require certain angle is helpful to make right judgement of what angle is going to work or which things will never work. |
The 100mm extrusion is interesting along with the rear diffuser in that they are 'behind' the wake yet effect it, the 2" diffuser is particularly effective , I am assuming it could be used with other Kammback designs with similar results / success.
None of those four are available. COME ON SON!
Thank you, Metro, for saving some of it. UGH. |
I found this, but it seems like it's more of an overview of the study in the first post? I haven't seen the original.
http://www2.warwick.ac.uk/fac/sci/wm...view_may11.pdf I'm sure they're stored somewhere. If someone wrote them a nicely worded email I'm sure they'd send you the files. |
:D It is amazing the power of the duct tape. |
Maybe, I'll have to look for an e-mail address. |
This link is working:
Information: How To Reduce Drag From 0.28 to 0.20 (Scholastic more than anything) Direct donwload from the Audi A2 forum is: http://www.a2oc.net/forum/attachment...9&d=1360233797 To read online in Scribd Session 4 - 1 - Hussain Ali - Drag Reduction on a Production Vehicle <p style=" margin: 12px auto 6px auto; font-family: Helvetica,Arial,Sans-serif; font-style: normal; font-variant: normal; font-weight: normal; font-size: 14px; line-height: normal; font-size-adjust: none; font-stretch: normal; -x-system-font: none; display: block;"> <a title="View Session 4 - 1 - Hussain Ali - Drag Reduction on a Production Vehicle on Scribd" href="http://www.scribd.com/doc/231804529/Session-4-1-Hussain-Ali-Drag-Reduction-on-a-Production-Vehicle" style="text-decoration: underline;" >Session 4 - 1 - Hussain Ali - Drag Reduction on a Production Vehicle</a> by <a title="View ALP1981's profile on Scribd" href="http://www.scribd.com/ALP1981" style="text-decoration: underline;" >ALP1981</a></p><iframe class="scribd_iframe_embed" src="//www.scribd.com/embeds/231804529/content?start_page=1&view_mode=scroll&access_key=k ey-Vy2o5Gpf6pRAadeWcKNU&show_recommendations=true" data-auto-height="false" data-aspect-ratio="1.3323485967503692" scrolling="no" id="doc_47833" width="100%" height="600" frameborder="0"></iframe> |
perfect combination
*The 2005 NUON NUNA,@ Cd 0.07 would be the 'airfoil' benchmark. *The 2013 Cambridge University CUER would be an okay 1/2-body benchmark,@ Cd 0.10. Mods which push a body in those directions would be winners. The key is the high sectional density and elongation which allow streamlines to converge without separation,leading to a higher base pressure. |
Cd values from bar graph
I did a photo-enlargement of the graph,measured each 'bar',then did linear interpolation to develop Cds for each 'bar.' With Cds attached to each mod,it's easier to evaluate their individual contribution.
Reading from left-to-right: *0.2881 *0.2818 *0.2656 *0.2383 *0.2353 *0.225 *0.2214 *0.2162 *0.2143 *0.2100 *0.2044 |
Last night I came across a paper in Sustainable Vehicle Technologies: Driving the Green Agenda (2012) by a Tata Motors engineer involved in this study. In addition to much more information on the project, they also took the car to the Soufflerie 2A aeroacoustic tunnel in Paris to test the various configurations with a moving ground. Here's what they report:
https://ecomodder.com/forum/member-v...re8411-s2a.jpg |
Interesting. Any idea of what 'suction upstream of the belt' means? Aren't the belt and the air moving at the same speed?
suction
