EcoModder.com
-   Hybrids (https://ecomodder.com/forum/hybrids.html)
-   -   Dream Prius (aerodynamic mod exercise for 2nd gen.) (https://ecomodder.com/forum/showthread.php/dream-prius-aerodynamic-mod-exercise-2nd-gen-978.html)
bestmapman 02-09-2008 09:52 PM
1 Attachment(s)
Here is what I want my Prius to end up looking like.
http://forum.ecomodder.com/attachmen...0&d=1202612003
The list of mods are:
1) Wiper delete
2) Rear wheel skirts
3) Front wheel skirts
4) Boattail
5) Side mirror delete
6) Front boattial
The question I have for all of you. How to accomplish each one of these mods.
SVOboy 02-09-2008 09:55 PM
Man, that image looks pretty sweet. 1, 2, and 5 should be very easy. 3, 4, and 6 depending on how fancy you want it to look when done, :)
Break out the welder! :)
trebuchet03 02-09-2008 09:56 PM
Do you want access to your hatch?
My response:
How nice do you want it to look? It's totally doable (with high quality as your image) if you're willing to put some bucks down for composites and such....
bestmapman 02-09-2008 10:00 PM
My response:
I'd like to do a pretty high quality job. I have worked with fiberglass some int he past and done some bondoing. Where I need to most help is in the frame and the structure.
It's been a long time since I did any glass or bondo work so I may need to get up to speed there also.
SVOboy 02-09-2008 10:05 PM
I think you'd be best set just taking the back end of the car off and doing some work a la coyote x to completely integrate the new bit into the frame as best possible and doing a basjoos style hatch, :)
bestmapman 02-09-2008 10:10 PM
On the hatch, I thought about extending the window by cutting off the bottom of the hatch window at the bottom and welding on another window from another hatch. This would extend the window and the hatch and keep all the same hardware and latches.
Welding I will need to get done somewhere. I don't have any experience there.
trebuchet03 02-09-2008 10:10 PM
^^ Done right - you won't need any frame... The glass can be your frame :) Then, the only thing you'd have to worry about is how to attach :)
Here's some tutorials I put together for building an HPV fairing:
large Scale Mold Making
Large Scale Tool Making
Large Scale Part Making
This thing is probably around the same size as what your boat tail would be.... We spent about $2300 for tooling and supplies to make that. We used glass that wouldn't shard when broken (a concern for us - not so much for you) which was pretty expensive compared to the alternatives. The most expensive bit - $500 to $600 of blue foam!!!
But, in theory - you can test out the fairing using the blue foam mold before setting anything in glass :D
bestmapman 02-09-2008 10:25 PM
Nice links. I'll look at them in depth tonight.
basjoos 02-10-2008 12:50 PM
Wow, nice project. It'll be interesting to see what kind of mileage improvement (especially at highway speeds) you can get out of a Prius with its Cd in the mid 0.10's.
I'm curious why you would want to delete the wipers when it would be fairly easy to make a windshield/deflector (as a rearward extension of the hood) that would keep the airflow from impacting the wipers, with the only drag penalty being the 1" high slot where the wiper would emerge from under the shield when being used. It would be interesting to see how they are handling the wiper on the Aptera, which also has a shielded wiper emerging from the base of the glass windshield.
Also are you considering installing a complete underpan, the partial underpan that comes on the stock Prius leaves a lot to be desired, aerodynamically speaking.
bestmapman 02-10-2008 01:12 PM
2 Attachment(s)
Thanks for the comments. Your probably right on the wiper shroud. The wipers on the Prius just stick right up in the windstream. I thought it would be easier to get rid of them and put them back on when needed with a quick attach fitting. Rear wiper is gone already.
I hadn't considered the upderpan so I am adding this also to my list.
If you ever get up in Kentucky, I would be real interested in seeing your mods up close.
the first thing I did was add aerohubcaps and rear wiper delete.
The next thing that I am going to do is the rear wheel skirts.
SVOboy 02-10-2008 01:22 PM
You could consider removing the blades and making a smaller shroud for just the arms themselves (assuming prius wipers are like mine).
MetroMPG 02-10-2008 02:08 PM
I'm with basjoos - undertray is also an important target. I know someone with a 2nd gen Prius who recently added a front tray and saw results from it, which he's still confirming by collecting more data.
I went to the local Toyota dealer this week with the specific intention of looking at the car's underbits - I think there's room for improvement in the rear floor area. (Unfortunately, they didn't have any on the lot or in the showroom for me to see.)
Also: I'd highly recommend playing with cardboard or coroplast & duct tape as a way of prototyping what you have in mind.
Lastly, I'd start at the rear rather than the front, for maximum gains first.
donee 02-10-2008 03:43 PM
Hi All,
I am another Prius owner. I am not so sure the hood extensition to cover the front wiper blades will be that effective. When a leaf or other bit of fluff goes up over the hood and windshield of the Prius its on a boundary layer only 1/4 inch thick. The leaf moves along very quickly over hood, There is no discernable slow down as it goes over the gap between the hood and windshield. Its unlike any car I have driven before. A wool tuft test might be in order to confirm this.
Even so, I changed the front blades to the Bosch ICON blades, which have a smaller profile than stock, and even lower than some of the other blade spring type blades. And with the winter we are having that was a good move for other reasons. These blades are sitting below the hood line projected to the windshield.
In other cars, one can use that hood extension to help change the air direction up the much more vertical windshield, well in front of the windshield. With the Prius, that change in angle is quite small. Indeed, one needs to runs with air recirculate off / with fan much more often to pull air from that point for sufficient defrosting.
There is also very little gap between the hood and the plastic bits to slide a piece of plastic under. So, it would probably need to be mounted to the top of the hood.
The other aero mod I have done to my car is adding 10 mil flashing to the stock Prius wheel rings to make a flush hub cap. The wheels are concave, so the flush hub cap was doable. The wheel rings snap into the a groove in the wheels. So far they have held up well in the heavy snow driving.
Oh, and I am running 3/4's grill block using insulation tubing. Which is a common Prius trick.
MetroMPG 02-10-2008 03:58 PM
Hi donee - welcome.
Certainly of all the items on bestmapman's original list, the front wiper delete would have the smallest impact.
Do you happen to have a picture of your trim ring mod? I'd like to see it.
donee 02-10-2008 04:20 PM
1 Attachment(s)
Hi Metro,
Here is a link to it over on Prius Chat ... http://priuschat.com/forums/prius-mo...rim-rings.html
Which describes how I made them. Here is a picture:
Attachment 313
Big Dave 02-10-2008 04:30 PM
The front wiper delete is not one of the things I'd do. It would be of little benefit and who wants a car that's afraid of the rain.
The rest of it looks doable and should be effective, although a Prius has a pretty low Cd as is.
Easy way to accomplish it.
Loan car to basjoos.
Introduce him to a good custom body man
Add money
Get car away from basjoos after project completion
Actually, almost any car would benefit from this approach. I am somewhat baffled as to why the VW TDI guys don't do stuff like this.
MetroMPG 02-10-2008 04:36 PM
Big Dave: I think the reason they may not is because they figure "we already get good enough mileage." Sort of like being satisfied that "a Prius has a pretty low Cd as is."
I'd love to see a Prius owner in particular do this, and then quantify the results. It would do wonders for raising the profile of aerodynamics in auto design and aeromodding as a DIY option.
Anything that opens people's eyes to the aerodynamic garbage the automakers are producing (in general) is good, in my opinion.
donee 02-10-2008 05:20 PM
Hi All,
Well, the reason I want to improve the Cd of the Prius, besides what I posted on PC, is that Excell, Hobbit et al have found what they call SHM, or Super Highway Mode. With a stock Prius, the car can hold this up to about 50 mph. At these speeds, in SHM, the Prius is getting 60 to 75 mpg demonstrated. With reduction in drag force, maybe SHM can be used at 62 to 64 mph (which is the max engine un-fired, still rotating speed) and is what the dictates of the proletariat on Chicagoland freeways pretty much force as a minimum crusing speed. Besides, I can't Drive 55.
There is a discussion on here about having to switch out one's final drive to gain the fuel economy performance lower drag would imply. Well, the Prius kinda does this automatically with its eCVT. There is a video on Google Video from Usbseawolf that shows this action at highway speed. And its quite noticable in a Prius too, when one drives in humid, not-wet overcast days versus driving in dry, sunny (heavy air) days.
donee 02-10-2008 05:24 PM
Hi Big Dave and MetroMPG,
There is a guy named Ernie Rogers who has modified his TDI Beetle. And claims to gain much improvement at highway speed. And after been in a Beetle recently at 45 mph, I can sure believe what he has done will have some effect. The roar of sheer vorticies to the outside of the car, right about the rear passenger head level is horrendous.
Of course diesels do not have throttles. So, while without gearing changes, there is no pumping loss improvement. The part throttle performance of diesels is very good, however. And when one lifts up on the accellerator, less fuel is injected. When less force is needed to push the car, its an imediate response that less fuel need be injected to keep the engine at the speed.
Reducing the pumping losses is probably why the diesel CVT Partnership for a Next Generation Vehicles (PNGV) were up around 70 to 80 EPA mpg. They could reduce fuel injection quantity, besides the number of times a second that quantity was injected.
MetroMPG 02-10-2008 07:27 PM
You'll have to excuse the tendency here to talk with the assumed starting point of an otto cycle engine & fixed gear (usually manual) transmission. (I'm happy to see a growing contingent of diesel members, and more than a couple of hybrid owners also considering DIY options.)
But your point about diesels not suffering from the part throttle, light load losses to the same extent as regular fixed gear otto engines makes Big Dave's question that much more relevant. Ernie took a New Beetle from its horrid starting Cd to something closer to "average"; what would be even more interesting would be seeing someone start with an "average" Golf TDI, for example, and make it much better than average.
The fact that the Prius, with its smart transmission, can avoid the BSFC problem fixed gear otto cycle engines encounter from lessening aero loads makes the prospect of aeromodding a Prius that much more interesting.
AndrewJ 02-10-2008 09:29 PM
bestmapman - I don't think that the front "boattail" is really neccessary in your situation. If the ideal aerodynamic shape is a teardrop, then you'd want the front of your car to, basically, be blunt. I think that something like Autospeed's front undertray and wheel spoilers would be a great starting place for the front.
As for the rear, your photoshopped version looks excellent! No complaints there :D
bestmapman 02-10-2008 09:58 PM
I really wasn't aiming for a point in the front. rather just to smooth things out and make the front more streamlined. The front currently has several openings for air intake to the radiator and resesses for the lights and hood. This needs to be smoothed out as much as possible. As of now, I have all of the grill blocked for winter. It will need to have some kind of adjustable opening for the summer months.
AndrewJ 02-10-2008 11:29 PM
cool, the adjustable grill seems like a good idea, I might go that way this summer if required. Spotted a nice choke cable in the auto parts store that would make a nice control system.
MetroMPG 02-11-2008 12:31 AM
Mapman: someone at Prius Chat is looking for volunteers to work with to build free prototype products (e.g. body kits) for a Prius owner.
http://priuschat.com/forums/prius-mo...roducts-2.html
bestmapman 02-11-2008 08:53 AM
I saw that. The problem is he is a long way away from me. Being in Virginia and me in KY near Cincinnati. Still I sent him a PM to see if we could get together. My first project will be the rear wheel skirts.
MetroMPG 02-11-2008 09:11 AM
I wasn't sure where you were located.
I think rear skirts are a good place to start. If you're going to undertake them yourself, I bet if you made them off a mold you could sell knock-offs to other Prius owners. The interest seems to be there.
Be a pioneer! I've been waiting for several years for a Prius owner to lead the charge. :)
MetroMPG 02-11-2008 09:25 AM
2 Attachment(s)
By the way: the idea of taking a vehicle like the Prius, with an already "better than average" Cd, and modifying it to make it even more aerodynamically efficient isn't unprecedented.
GM did the same thing with its Cd 0.19 Impact/EV1 for a record speed run:
http://forum.ecomodder.com/attachmen...1&d=1202739747
http://ecomodder.com/forum/attachmen...1&d=1202745496
(source)
Note the ...
  • extended boat tail,
  • lowered ride height,
  • smooth wheel discs,
  • rear wheel skirts (stock on the production EV1)
  • full grille block (the EV1 ultimately had no grille, but some versions of the Impact prototype had stylistic openings, as well as openings for electronics cooling)
  • external mirror delete,
  • improved deflectors ahead of the front tires,
  • ... and lots and LOTS of speed tape!
krousdb 02-11-2008 12:30 PM
Originally Posted by donee (Post 9118)
Hi Metro,
Attachment 313
Have you quantified any FE gain with these?
donee 02-11-2008 06:03 PM
Hi Krousdb,
Do not know and have not tried to evaluate the hub caps yet either. I did them at the start of the winter, and good conditions really have not existed yet for testing. Coming up with a method to see as small a difference as I expect will be difficult as well. One of the reasons I made them out of about the lightests metal that might work is to avoid the effects of rotational momentum and extra unsprung weight.
The secondary reason for doing the hub caps is the rust spots on the brake disks when they were warm, and the snow would blow in and melt on the disks. As you know the Prius does like 85 % of its braking electrically, and so the friction brakes do not get hot enough to evaporate out the surface moisture on many trips. So, this seemed a good way to keep the surface moisture down. Which the flat hub caps do help with.
Big Dave 02-11-2008 07:43 PM
I'm not saying: "Don't do it!" I love seeing guys take their ideas as far as they can. Gives me more ideas to steal.
Basjoos started out with a brick and took it to the max and got fabulous results.
Just that starting with an already slick Prius means you start closer to the point of diminishing returns.
Like I could ever see that point with my full-size pickup.
diesel_john 02-11-2008 07:46 PM
1 Attachment(s)
bestmapman, i am 17 miles east of eastgate.
here's a pic of Ernie's
Lazarus 02-11-2008 07:46 PM
(source)
Note the ...
Great find. Love the duct tape.:thumbup:
bestmapman 02-11-2008 07:49 PM
We'll have to get together.
krousdb 02-12-2008 07:51 AM
Lynchburg, Va is about 180 miles from me. I sent him a message asking for details.
krousdb 02-12-2008 12:50 PM
Hi All,
Donee,
I was thinking the same thing about SHM, perhaps being able to extend it by a few MPH by reducing drag. I have done some testing and found that for my Prius, on a fairly level surface, I can maintain SHM up 47 MPH at just over 71.8 MPG with temps in the mid 50's F. Anything above that and the FE drops quickly.
Just to give you some idea on how the low the Cd would have to be to achieve SHM at higher speeds. Assuming that SHM can be maintained up to 47 MPH in my case, I calculate 7.42 HP is required. If I increase the speed and maintain 7.42 HP:
- At 47 MPH, Cd = 0.260
- At 50 MPH, Cd = 0.205
- At 55 MPH, Cd = 0.142
- At 60 MPH, Cd = 0.099
- At 65 MPH, Cd = 0.070
I would be happy with 0.14 I think.:D
bestmapman 02-12-2008 01:12 PM
I think .14 is doable. The car will have to look something like the aerocivic when done.
aerohead 02-12-2008 02:28 PM
Dream Prius
Why this would not be a market success is completely beyond me! I can only hope that some visionary wannabe at Toyota will rip-off the entire concept,ram it into mass production,and flood the streets with them.A non-hybrid version could be co-produced for sale to the feint-of -heart,not quite ready for all the technical sophistication of the hybrid.The highway performance would still be there,and it would certainly get people talking at the fuel pump.I'm afraid that automotive-related knowledge will continue to spread from the bottom up.This would be a terrific vehicle to deliver the message! It's a beautiful car,thanks for putting that image together,and bottoms up!,Phil.
gotzip 02-13-2008 05:02 PM
Desperately seeking source
Hi BestMapMan. I write for Edmunds (http://blogs.edmunds.com/GreenCarAdvisor/). I'm working on an article about ecomodders and would like to communicate with the person who crafted that awesome red machine. Please, where did you come across it?
tasdrouille 02-14-2008 09:36 AM
.14 is really pushing it. Just the basic shape with wheels might make it to .14, but even that is optimistic. As soon as you start to add the windows recesses, joints, wheel wells, muffler, radiator, etc. that .14 is far gone.
basjoos 02-14-2008 04:01 PM
That awesome red machine doesn't exist yet except in bestmapman's imagination. It's a photoshopped image of what he wants his Prius to end up looking like. It'll be amazing to see once it becomes reality.
