Old 09-20-2009, 05:54 PM   #1 (permalink)
Silver Turtle - '02 Ford Focus Zx3
90 day: 38.83 mpg (US)
Question --1 watt led vs 5 watt luxeon --
Will 5 1watt leds be the same as one 5watt luxeon?
They will use the same wattage (I guess), but will the intensity and "quality" of the light be the same?
I am trying to build an LED lighting system for my saltwater tank, and I can choose between A BUNCH of 1 watt little 5mm leds or 5-6 single 5watt luxeon leds... ?
Old 09-20-2009, 08:54 PM   #2 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
The wattage doesn't tell you that. You need to compare the luminous flux (lumens), which will be the same only if the LEDs are equally efficient.
improving mpg's with led taillights? GenX Rolla EcoModding Central 38 11-02-2022 11:03 PM
My LED tail light conversion BrianAbington EcoModding Central 52 12-06-2011 06:42 PM
LED Headlight captainslug DIY / How-to 82 11-15-2011 01:32 AM
LED lighting goes mainstream! It's at Wal-Mart! bennelson Saving@Home 81 08-07-2010 11:18 AM
Article: Hella LED Headlamp Study TomO General Efficiency Discussion 14 10-21-2008 02:39 PM
