Dumb Idea of the Day(TM)?: removing a compression ring to mimic the XFi 1-ring piston
Whenever someone asks if it's worth swapping in the XFi 1-ring (compression ring) pistons in place of the garden variety 2-ring style, the opinion seems to be: probably not worth (it in terms of fuel economy gains), unless you're taking the motor apart anyway to do something else.
The implication is that the gains are probably pretty insignificant. Then Peter7307 posted some interesting figures about the relative amount of friction from bearings, pistons & valvetrain for a Mercedes 2.0L gas engine operating at 2500 RPM and medium load (in the thread about valve spring strength as a possible efficiency mod). Total engine friction losses were estimated at 1.5 kW:
(Anybody know approx how much power a 2.0L gas engine would be making in those conditions?) Anyway, the relative amount of piston drag got me thinking about the XFi pistons again, and thus the Dumb Idea of the Day(?) TM: Would removing the bottom compression ring be feasible for non-XFi owners? Here's the XFi piston. Anyone got a pic of a regular piston to compare to it? http://metrompg.com/offsite/xfi-piston.jpg |
you can either collapse the second ring or leave it out. We did this on qualifying motors where we didn't want as much drag on internal parts, racing oil filters are another trick (i.e. NASCAR restrictor plate tracks, less filter media to push through, less horsepower)loss
1 Attachment(s)
http://ecomodder.com/forum/attachmen...1&d=1234242590
Not really worth changing the pistons. Just leave the second ring off :) |
You would have to be hardcore about economy to do this.
The gains could be noticeable, but at the expense of increased oil consumption and blowby. Does the crankcase ventilation go directly back into the intake on this engine? If not, the blowby, consisting of unburnt hydrocarbons, etc, could cause more damage to the environment than you would save in fuel consumption reduction. If you reduce the engine compression sealing ability far enough, you'll end up with lower power and worse economy. As for the overall engine output at this condition, with only 1.5kW of total friction loss, it wasn't making much... Total engine friction power loss at low loads and speeds is often half the engine output. Your link is dead though so I'm not sure I have the whole story. |
Yes, the engine has positive crankcase ventilation back to the intake, so if there is any additional blowby, it's going to get combusted. Quote:
Another potential downside is faster ring wear. Though if I recall, Coyote's experience with these motors is they pretty much require a rebuild at 150k miles regardless of XFi vs. garden variety. At the rate I drive, that means I should set aside some time to tear it down around 2055. Yet another potential downside someone has pointed out privately to me: the ring spacing may be different between the 2 piston styles, to keep the piston properly aligned in the cylinder vs. thrust angle. If the piston is "unbalanced" it could cause scoring. Quote:
PS thanks for the pic, Coyote
I had a picture I found from teamswift of both piston types side by side and the top ring is in the exact same position on them both. The only difference is the xfi piston doesn't have a second ring groove cut into it. So really just leaving the second ring out on a metro will work fine with no trouble.
If I had a base metro I would tear it down and take the second ring out but I don't really think any normal person would be willing to do that much work for what would probably amount to 1mpg. For a metro needing a rebuild there is no question I would say leave out the second ring. |
Oooh. Thanks for the info, Coyote. I went searching for said photo @ TS last night with no luck. Comparing your pic to mine of the XFi piston, the oil ring looks set a bit higher up on the XFi, but it's nearly impossible to tell from 2 different pics.
Anyway, I wouldn't tear the motor down just to pull off a compression ring, but I'm considering shaving the head as well, plus swapping in an old (potentially softer) set of valve springs. Time to start making use of that old 1.0L I pulled from the blue ForkenSwift. |
don't shave the head unless you want no end to pinging and general trouble :)
I am going to swap mine back to a stock head once the weather gets nicer. If you want to do any head work the best bed would be just a mild deburring/smoothing and put some stainless exhaust valves in it. A 3 or 5 angle valve job might be something to try. I am really not sure if any of that would give you much though but it would probably run smoother. And if you are going that far into the engine a crank scraper and screen windage tray would be worth adding at the same time as well as deburring the rods and bottom end. Also I think that piston was out of a 4 cyl so the rings wont quite line up even if you could get them side by side. I will look around some and see if I can find that picture. Maybe I will get lucky :) |
Really? I was at TeamSwift yesterday re-reading your head-shave reports, and they seemed positive to me! You should go back and update that thread. :P
The pinging's no huge surprise, but I'd like to hear about the "general trouble". You took Mike's advice and went for the .040 reduction, right? If you could put some back, would you? Or would you only go right back to stock? |
Well, .040 is a lot to take off a head. I took .025 off my Paseo's head and I got no problems at all. If I knew what I know now about head design I'd go a bit further.
Tim, are you running timing advance too with that shaved head? All on regular gas?
Kind of straying from the topic of piston ring-ectomy, but whatever. |
I would say most of the gain I got was from fixing the burnt valve and doing a mild porting and polishing of the head. After running with the audio knock sensor for a while after doing it I pretty much figured that shaving the head caused more tuning issues than the gain it gave me. It will also take a lot of your bottom end power away and make it suck under 1500rpms if you want to keep the knock halfway under control.
With a stock computer and no knock sensor it might not be apparent but I bet the engine won't last as long with a shaved head. It would have a much higher chance of bottom end failure from the knock. I would guess 75-100k miles. My setup has a pretty good bit of information available to help tune out the knock and even with 93 octane it cant take more than 1/4 throttle under 2000rpm. That was with the timing at -10 degrees so it is mainly compression causing the knock and not spark timing. 020 might be ok to try but really with a year of messing with a shaved head I am pretty much ready to give up on it. Unless I can get a reliable water injection system working then I will want to shave a bit more off :) |
Burn E85 in it
I think that you want a special ring with overlapping ends if you are only going to use one.
You mean gapless pison rings.
Total Seal Rings Top-End Performance Another fun idea is getting the piston skirts coated with anti-friction material, and the tops with ceramic. I don't think anyone has done it for mileage and documented the results. |
The Paseo uses a distributorless ignition system. There is no easy way to alter ignition timing as the computer handles it completely. I just let the computer advance it as much as it feels it should. It is possible that it retarded timing a bit when I shaved the head. I unfortunately have no way of knowing for sure.
No, no, no. I got that part! :D
Let me rephrase the question: why wouldn't you also want less drag in the racing engine? Why limit the mod to the qualifying engine? If it helps in qualifying, won't it also help in racing? |
I have to put rings in the motor I got from Coyote.
I may go ahead and order Xfi pistons and ring set when I get started doing the work. I have found it to be in my best interest to do pistons with rings during a tear down. Got burned once by a cracked ring groove and it left a bitter (and expensive ) taste in my mouth. I'll keep you posted. S. |
Schultz: I know a guy who may have some used XFi pistons. (He offered them to me a while back, but I passed.) Want his contact info?
