EcoModder.com
-   Hypermiling / EcoDriver's Ed (https://ecomodder.com/forum/hypermiling-ecodrivers-ed.html)
-   -   Dumb slushbox question? (https://ecomodder.com/forum/showthread.php/dumb-slushbox-question-3163.html)
joebedford 06-18-2008 02:58 PM
I'm still new to all this, so there's a point I need to clarify: I can't shift my auto trans into neutral to coast unless I'm going to stop, right? Because you don't want to shift from N to D when moving...or is that wrong?
IndyIan 06-18-2008 04:31 PM
This is a question that no one seems to know for sure...
I shift from N to D maybe 20 times a day at around 55 mph, I rev match by giving a shot of gas revving past the target rpm and then let off and shift into D as the rpms drop, makes the shift smoother. I also EOC for a km or two at a time, this maybe bad also, no one really knows...
I've done it for 3 months, only 6000km, no problems yet, I'll report if any develop. I'm assuming my car will die from old age/rust before the tranny has any issues from me fooling around.
If I had a new car with lots of payments to go then I might not do it as much but I do get almost 10mpg more so I guess in 4 years the savings pays for a new transmission.
Automatics are fairly tough, I've seen a few N to D drops from the rev limiter with no causualties and how they handle full throttle upshifts and downshifts is a mystery to me.
Ian
