EcoModder.com
-   -   E15 Holly Crap Batman (https://ecomodder.com/forum/showthread.php/e15-holly-crap-batman-40152.html)
nemo 04-13-2022 09:03 AM
Estimated $.10 savings at the pump! Will it represent a savings at the wallet, lower mileage vs purchase price?
hayden55 04-13-2022 10:39 AM
There's around 2% less energy in it than E10 so multiply the price by 1.02 to get the E10 GGE equivalent.
me and my metro 04-13-2022 10:58 AM
I can’t wait! Less miles per gallon again. Now it will get a rock solid 29. 🤮
Tahoe_Hybrid 04-15-2022 04:46 AM
Originally Posted by me and my metro (Post 666103)
I can’t wait! Less miles per gallon again. Now it will get a rock solid 29. ��
how will that decrease fuel consumption if i'm using way more
#smooth-brained president
100% gas would gain mpg ... this could explain the testing they did over the winter to see if anyone would notice...
I mean getting 9-13mpg was not even normal what so ever.. most likely testing higher Ethanol to see if people would notice
most likely testing E30 to E50
nemo 04-16-2022 07:19 AM
It's not about usage, it about (theoretically) increasing the fuels supply so the price goes down. It seems there a whole lot of people complaining about high gas prices. :rolleyes:
Tahoe_Hybrid 04-16-2022 04:05 PM
after counting in repairs or retrofiting that would be quickly cancel out any savings :rolleyes:
Drifter 04-16-2022 06:54 PM
The goal is to decrease oil use, not fuel consumption. You're replacing ~15% of oil-based gasoline with plant-based ethanol (which should lower mpg ~7% compared to pure gasoline).
If I'm doing my math correctly, the net result should be America using ~9% less oil to drive the same amount (but paying more to do so)
freebeard 04-16-2022 07:19 PM
I went looking to see if there is info on how much oil is burnt to produce the ethanol, but I didn't find it here: e360.yale.edu: The Case Against More Ethanol: It’s Simply Bad for Environmentt
Tahoe_Hybrid 04-16-2022 07:44 PM
that is canceled out by lowering the mpg Net savings is zero possibly negative depending on how the car reacts to it
if i get 3mpg less because of it then i'd drop down to about 16 instead of 22 with real 100% gas
Drifter 04-16-2022 08:49 PM
Again, you will burn more gallons of fuel to go the same distance but in doing so you should, in theory, use less oil.
1 gallon of pure gasoline - E0 - has ~115,000 btus
1 gallon of pure ethanol - E100 - has ~76,000 btus
1 gallon of E10 has ~111,000 btus (~3.5% less than gas)
1 gallon of E15 has ~109,000 btus (~5.2% less than gas)
So you should be getting ~5% (not 7% as I said earlier) worse mpg on E15 while, in theory, consuming ~15% less oil.
As Freebeard mentions, it does take considerable energy to produce ethanol (~35,000 btus worth of energy are needed to get ~76,000 btus worth of ethanol) so it isn't a "green" source of energy like the corn industry would like us to believe. But ethanol can be produced 100% domestically so your money stays in America rather than going to hostile leaders like Vladimir Putin, Saddam Hussein, Osama Bin Laden, etc.
Edit: And to be fair, it takes a lot of energy to produce 1 gallon of gasoline too - especially if the crude oil has to be transported half way around the globe.
