EcoModder.com
-   -   Easily removable top for boattail ? (https://ecomodder.com/forum/showthread.php/easily-removable-top-boattail-23816.html)
Cd 10-28-2012 04:08 PM
I was farting around sketching some on an idea for a boattail that i will never build for my car.
Since i will never build this thing, i thought i would see if anyone here has had any similar ideas.
One of the issues with building a boattail is access to the back of the car through the hatch.
Here is an idea that allows a full size bicycle to be loaded into the back of the car without lifting the bike overhead.
Instead of building a larger hatch and attaching it to the original hatch mounting points, this hatch simply lifts off with four quick fasteners.
http://farm9.staticflickr.com/8475/8...9e6eb698_b.jpg
If needed, two support beams can then be released and slid to the side, again with quick fasteners.
http://farm9.staticflickr.com/8049/8...da9e1e1bbe.jpg
This allows full access to the back 'trunk/boot' of the car .
http://farm9.staticflickr.com/8335/8...f319830c26.jpg
freebeard 10-28-2012 07:15 PM
Early 50s International trucks and Buick cars had a hood that had an integrated latch/hinge mechanism on the sides. You could unlatch and lift either side, or do both latches and lift it off completely. I'd want to incorporate locks, too.
brucepick 10-29-2012 03:21 PM
Hmmm.
Could possibly make the center and rear panels out of lean or acrylic and be able to see out the back.
christofoo 10-29-2012 04:05 PM
I've been thinking about a side-latched or front-latched hinge, maybe with optional detach, and also thinking steel reinforcements for the bottom. I think it's a mistake (at least in my usage) to neglect the "truck-like" qualities of a hatch. The right boattail design could enhance the truck-like functionality rather than hinder it. (By truck-like functionality, I mean odd-size loads, not to exceed 200ish lbs in the tail.) A detachable side-latch hinge seems like a no-compromise design to me.
Sven7 10-29-2012 04:22 PM
If you're removing the top, why not extend its sides down to the cargo floor level? Then you could attach the top half to the stock hinges/struts and take advantage of what's already there.
This would almost certainly have to be rigid- fiberglass or something. Maybe a rigid structure with all the panels made of clear acrylic or lexan
freebeard 10-29-2012 07:32 PM
Oh, I see now what you did. Four of us stepped right up.
Cd 10-30-2012 04:36 AM
Originally Posted by brucepick (Post 336764)
Hmmm.
Whuups .... actually, there are windows in the illustration . I'll have to colorize those areas.:o
I was looking at the cost of Lexan in large sheets and also thinking of the problems with complex curves, so why not use a minimum of the stuff and just have windows in the areas that are the real blind spots ?
If you notice, only the bottom half of the tail is Lexan, since this is where the line of sight is when i look out the window. Any more is wasted cost.
Also, there are windows on the sides, but no complex curvature is involved.
Cd 10-30-2012 04:40 AM
Great idea.:thumbup:
The main issue here being weight.......unless the tail was made from Coroplast ( Which i intended to do by using sections of the stuff for complex curves )
basjoos 10-30-2012 09:16 AM
Looks similar to mine.
http://img.photobucket.com/albums/v4...tRebuild11.jpg
Cd 10-30-2012 12:25 PM
Yup. I was inspired by your tail Mike :thumbup:, but I wanted to change a few things about it to save cost ( the windows ) and provide easy access to my bike.
euromodder 10-30-2012 01:47 PM
Or extend just the rear end down to cargo level, and keep the sides on the lower, sturdier structure - doing so makes the hatch lighter.
