Old 04-16-2014, 10:16 PM   #1 (permalink)
3-cyl engine into a compact truck?
I guess you all might know the Triumph Rocket III Roadster, with its 140cu.in. straight-3 engine.
Since its 163lb.ft. torque peak is surprisingly achieved at a lower engine speed than the 154lb.ft. in the Duratec 23NS formerly used in the Ranger, would the 3-cylinder engine layout be a reasonable option into a compact truck?
Old 04-16-2014, 11:08 PM   #2 (permalink)
Drive less save more
ecomodded's Avatar
90 day: 60.42 mpg (US)
its not too bad but not as good economy as say using a 1.9 tdi which makes its max torque 150lb to 180 ft-lb at 1900 rpm.
My thought is that triumph motor has good torque and hp which would be nice for a trike or anywhere lightweight is needed like say a stream liner.
Save gas
Old 04-17-2014, 06:53 AM   #3 (permalink)
The point I was considering is actually the # of cylinders in a same displacement range. Regarding Diesels, I know of some 3-cyl ones in a 2.9 to 3.3L range which are available in my country and can be fitted into a Ranger or any other compact truck.
