Ecomodding an automatic '04 Civic Sedan
1 Attachment(s)
Note: Click here to go directly to the start of the actual modding build part. :) The rest is mostly dialogue about my car and asking questions related to ecomodding it. ▲▲▲▲▲▲▲▲▲▲▲▲▲▲▲▲▲▲▲▲ ------------------------------ Also as a side note, the 42+ mpg obtained in my introductory post below was on "longer" (30+ minute) trips. My current modding baseline prior to modding is 38 mpg due to most trips being 10 miles or less. ------------------------------ Hello all! Yes this is my first post, and yes I am new to Ecomodder. :) I'm also a newer driver (newer is relative), and this '04 Honda Civic EX sedan is my first car. Yes, it is an automatic, don't hate me for it (my next car will probably be a manual though). Now if your area is anything like mine, most new drivers get lumbering SUVs or buy Civics to trash around. But being the nerd among my associates I decided to buy a Civic, keep it stock, and see what kind of MPGs I can get out of it. Well at first it went well. When I bought it I knew the brakes needed to be changed, but drove around in it a little using basic hypermiling techniques and averaged 39 MPG - decent considering the new EPA combined estimate is 30 MPG (because no, this is not an HF or a VX, as I didn't want a coupe). Well after changing brakes my MPG went down to 25, kind of disappointing. Looking at the problem revealed a bad brake caliper. The caliper was already bad, but somehow worked until it was remounted during the brake change. Once that was replaced and a new air filter was installed, I drove it around with much greater success. First trip was 44 MPG, second was 52 MPG, third had some traffic and was 38 MPG, and the trend continued. And yes I was hypermiling, just for the record. Anyway, the rest of the tank averaged 42.2 MPG (~40% above EPA and with winter blend gasoline as well! :D ). Final tank ended up at 34.1, which isn't bad considering the 25 MPG from the brake caliper had brought my average down from 39 to 29. However with all issues fixed, looking forward to starting a trend of 40+ MPG tanks (and maybe closer to 50 in the summer)! No mods done to the car, however I may install a removable grille block for winter time and possibly some underpaneling. My key thing here though is for my Civic to look and be stock -- too many Civics are modded to look like ricer junkies, and that I am determined my Civic will never look like. My biggest goal is to get a 50 MPG tank just once, but we'll see if that's achievable. Want to give a huge shoutout to all the extremely helpful hypermiling tips listed on this site! They've definitely helped me learn how to best squeeze the most miles out of my car (despite it being an automatic) as well as better pay attention to surrounding traffic to avoid being perceived as one of those completely rude drivers out there. ;) |
2 Attachment(s)
https://www.youtube.com/watch?v=jk6uaHJE7r8 Quote:
Attachment 23518 Attachment 23519 You should be able to get some pretty helpful mods in even with maintaining a stock appearance. My car remained mostly stock looking for a while because of parents...:rolleyes: Add an engine block heater to your list of potential mods, they are cheap, effective, and very nice to have in the cold. Quote:
Welcome to the site and congrats on the great mileage with a stock automatic! Nicely done.
We have a member that wanted an HX and four doors. He did not make excuses.
Those are some sweet RPMs though! My tach only works sporadically (and I haven't gotten a gauge yet for that) so idk exactly what my RPMs are, but I can safely guess they're higher due to the civic being a smaller vehicle. I know it seems to hit 4th gear around 41-43 MPH (or so it feels like) and on that 52 mpg trip I was going around low 40s since there wasn't much traffic, so something must be right there. And of course having 6 gears on your Accord beats the 4 on my auto! Quote:
I think I remember reading somewhere that the manual gets slightly better MPG in city due to the gearing and the auto gets slightly better MPG on the highway due to a lower gear ratio in the highest gear, but that obviously doesn't take into consideration the manual's better ability in hypermiling. Quote:
I avoid automatics whenever possible, but my car was $1,050 less than this one: https://phoenix.craigslist.org/wvl/c...479733847.html
with 60% as many miles. That is enough to pay for 85% of the gas that I have used in sixteen months. Sometimes plans come together for me. The rest of the time I see squirrels at just the worst moments. |
For that one, I used owners.honda.com. Select vehicle info in the top left corner, and you can get specs for each trim level. I usually use cars.com though. You can select research cars, pick the trim level and scroll down to specifications. From there I use the Engine RPM calculator from CSGNetwork, scroll all the way down so you can use the calculator with four variables specified: Axle ratio, tire height, speed, and gear ratio. Once upon a time I did tire height calculations manually, but now I just use tiresize.com 's tire height calculator. Now do me a favor and find me the secret source for figuring out motorcycle gear ratios! :( Quote:
You might be interested in this.
Too bad about the automatic; with a manual, you could wire in a fuel injector kill switch (someone else on the forum figured out which wire to cut on the 7th gen, and a few of us followed suit) and have some real fun. |
Also the pictures on the post didn't show - showed some kind of "third party sharing disabled" thing :( had to go to your car's profile page to see it. |
My grille blocks stay on year round but I monitor engine temp with an UltraGauge... |
Hopefully I can get a bluetooth adapter hooked up soon so I can connect a phone to it and monitor temps and stats that way. Going for mods that can be reversed easily back to stock appearance with no drilling, taping, gluing etc. And using the cheapest materials possible. |
Some more questions here...
Other than the lower engine cover that comes standard on the 7th gen Civic Hybrids here) what other aero mods were done to the Civic Hybrid that can be incorporated into my Civic EX? From what I've read, the 7th gen Civic has a drag coefficient of 0.36 but the same gen hybrid has 0.28. Seems like a lot of possible gain here. And also, does anyone know of a tool somewhere to calculate the minimum speed of each gear? My Civic seems to shift into final overdrive between 40 and 42, but my tach is broken so I can't verify (one of those things I need to fix when I have time). Is there a way to calculate minimum cruising speed for each gear? Maybe using gear ratios or something? Or is it purely a vehicle by vehicle basis? |
4 Attachment(s)
Attachment 23638 The differences visible in the hybrid here are the smooth wheels and the trunk lid spoiler. Attachment 23639 Attachment 23640 Both cars seem to have rear wheel spats, so no improvement there. Attachment 23641 Quote:
Planning ecomods for my Civic
1 Attachment(s)
So while waiting for circumstances to give me the ability to start ecomodding my car, here are is what I've come up with to do:
- Smooth coroplast wheel covers. Easy to restore to stock by cutting a few zip ties. - Pipe insulation to block upper grille. - Coroplast to effectively block portions of the lower grille. Coroplast "fan blades" to cover fog light area to increase aero. - Possibly use coroplast to duct incoming air into the radiator. - Air Dam - lawn edging mounted onto front bumper. - Possibly see if I can obtain the engine bay belly pan from a same gen Civic Hybrid to install. Attached is a rough idea of what I'd hope the final product to look like (thanks to Microsoft Paint): http://ecomodder.com/forum/attachmen...1&d=1521387437 What do you think? Any tips, suggestions, or improvements? Should I paint it black or try to match the silver? I'm also considering automated grille shutters if I ever become knowledgeable enough to wire them up. All mods must be easily restorable to stock (unless I replaced the part such as with the bumper and grille, but kept the original bumper and grille). |
Looks promising.
An automated grille block would not be hard to do at all. |
All that said, I agree with teoman that an active block is objectively simple. It is not like building an arduino or something objectively more complex. That means the learning curve is easier. Good luck, hey. |
I guess. I suppose I should take it one mod at a time instead of trying to do everything at once that takes master ecomodders months to accomplish. ;) One day though, I will figure it out.
I’d focus on one mod at a time... you keep talking about resale value and returning the car to stock; do you intend to sell it soon?
No, I don't plan on selling it for a long time. Car has 153K miles on it and Hondas should last well past 300K if properly taken care of, so the car has plenty of life in it since it's in excellent condition right now. I guess I'm just used to my family reselling cars when they reach the 250K mark and still getting $1K or so for them. I guess it really just depends on where I'm at when that time comes.
And as far as the returning to stock part goes, well, maybe someday I'll just get tired of hypermiling/ecomodding. I know, such a sacrilegious opinion to share on a forum like this, and I have no intentions of stopping anytime soon, but who knows. |
When you own a car for twenty years and do all the work on it, you know every flaw. You can eventually ID and repair any failure. If I sold for a grand (assuming I could), a replacement vehicle would be a mystery. Surprise failures would start appearing. When it comes to the go-box, I don't like surprises! Lol.
I second the above opinion... if you’re gonna sell/trade, obviously do it before too much irreversible modding... otherwise, I’d do whatever you feel necessary... realistically if I were spending $1k next a car, I’d not expect it to look pristine... however, using tape shouldn’t hurt the finish at all... most residue comes off with some goof-off...
Most of the mods of the aerodynamic variety also help speed, just some food for thought... not only cheaper to operate than the garden variety 04 Civic but also faster on the freeway and maybe with less lift, translating to better high speed stability... It sounds like you’re gonna keep it a while though, so the more cheap kids you have, the cheaper your operating costs will be in the long run |
But true, owning the same car for as long as the vehicle lasts does have its advantages. Prior to buying this car I literally knew absolutely nothing about a car's engine--and I still don't know much--but I'm hoping to learn for myself instead of just relying on mechanics to do everything. Quote:
If my tranny dies but the rest of the car is in good shape I'll see if I can replace it with a taller one for even better FE. :cool: But the car is in excellent shape and should run for a long time yet. |
That’s how I ended up feeling about the Malibu I had... initially I didn’t like it and the more I drove it the fonder of it I became... 36-38mpg from a midsize car wasn’t too bad in my opinion...
Even though it's an automatic? :eek:
But yes, I'm not at all dissatisfied with my Civic; I'll just be even more satisfied with it once I reach 50 MPG. :cool: |
I didn’t like it at first but after I started caring about fuel and ecomodding it/hypermiling it, I became quite fond of it... I bought my fiancé a 2006 Saturn Ion coupe with the 4T45 automatic and it isn’t too bad to drive... after my operation I can drive stick well enough again that I don’t wanna go back to two pedals unless something happens to my car and I can’t find something in manual... |
Back again after a brief hiatus...just got a working OBDII Bluetooth adapter to work with the Torque app - in all about a cost of $23 instead of $90+ for a Scangauge that doesn't have as many features or as clean of a display.
Does it work? It sure does! My last tank was 37 MPG with a lot of short trips that prevented me from getting over 40. Well today was my first drive using Torque, and I managed to get 42 MPG despite a slight breeze blowing against me most of the time. I have to places I go to on a daily basis, one of them is a more fuel efficient longer drive with fewer stops, while the other is a shorter drive with more stops, and it was on this shorter drive that I got 42 MPG. Hoping for over than tomorrow on my "longer" drive; should hopefully have no problems beating 40 MPG in this tank with the only mods being tires @ 41 PSI, torque app, and of course adjusting the nut behind the wheel. Only waiting for my scheduled timing belt change before starting actual ecomodding. 50 MPG looks more promising than it did yesterday! :D |
Honestly instrumentation is just as important, if not more than, as the other mods
