Ecomodding a Classic / Antique Car or Truck
Here are the basic parameters:
Must have been built before 1974. Bodystyle is open. Modern updates are fine. What would your choice be and why. |
3 Attachment(s)
Actually I bought this a year ago, for $700 on craigslist. The sellers father started building it in the the early 1980s. It's a Fiberfab MiGi kit on a 1973 VW chassis (not super beetle). The original VW had just over 63k miles. He ran into a problem with the wiring and ended up cutting a bunch of the original wiring and giving up. He never finished the transmission tunnel work to reconnect the shifter, clutch and throttle cables. I welded in the missing part of the transmission tunnel from a donor car and got it so you could drive it, but it still needs wiring. I have a painless harness that came with the car for an extra $100. It has all of the top parts and interior parts except for a couple of pieces of carpet.
It has the original 1600 dual port Vw engine in it right now, but I was considering other options like a small diesel or even battery electric drive, if I could find some battery options that wouldn't weight 1000 pounds. Right now the front end is so light I can left one of the wheels off the ground. I may eventually make it a diesel hydraulic hybrid. regards Mech |
You got yerself a deal, that's a very nice looking car.
I remember the FiberFab products; used to have one of the biggest lines of kits available. |
Lotus Europa, with the engine & hybrid system from a 1st Gen Insight.
Or FTM I'd take the early '60s Austin-Healey Sprite I used to have, as it was :-) |
72 Vega!
Another Vega
Me too!
I also have a 1972 Vega. It's a hatchback GT coupe, bone stock, but unfortunately has the 2-speed air-cooled Powerglide, is geared very low and has a 2-BBl carb (not progressive). I want to keep it as stock as possible, but maybe drop in a 200r4 to get OD and lockup, as well as a progressive carb. The manual trannies were only 4-speed but 4th was a tall gear and they could get 32 mpg or so. The Powerglides could only get 18-19. Mine was built for sale on the west coast and has the tilted windshield washer reservoir for the VertiTilt shipping scheme--but that's another story.. Oh, I forgot-it's not quite stock, it has a reman engine with steel sleeves. Ray Mac |
Had one of those Vegas, too, back in the '70s. It's the reason I've never owned an American car since. |
If I was shopping for a car then I would go for a classic Mini Cooper and get the kit to put a V-tec Honda Civic engine in it then go with the D15z1 engine.
Otherwise I think I'd go for a Honda Z600 coupe and figure out how to put fuel injection in it maybe even replace the large flat alternator that they have with a hail affect sensor and have it work as the starter as well for automatic start stop and mild hybrid. 3rd option would be a Seabring Vanguard Citi-car, the first year they built them was 1974 so it would just squeak in under the topic rules, install lithium batteries, a rear axle with a regular drive shaft so the motor didn't have to be unsprung and install a larger electric motor. |
