EcoModder.com
-   -   The effect of a cold air intake on mpg (https://ecomodder.com/forum/showthread.php/effect-cold-air-intake-mpg-25613.html)
Joe1234 04-20-2013 02:43 PM
I have a Civic VX that is completely stock. Will a cold air intake make my mpg worse all other things being the same? Anyone have test results from a similar scenario?
kach22i 04-20-2013 03:43 PM
I've always understood that warm fuel and cold air garnished the best results, but found that many will argue with me on these points.
I know nothing.
Experiment in an A/B fashion and post your results.
Joe1234 04-20-2013 04:27 PM
I would have to waste the money required to buy a cold air intake and the tons of time that would be required to get a decent set of results to know the answer. That's why I asked here first hoping that someone has already tried it.
NeilBlanchard 04-20-2013 04:39 PM
I have a cold air intake - I don't think it matters very much; but that is just a WAG. Mine cost a lot and I know it was not worth the money.
oil pan 4 04-20-2013 04:59 PM
Rig something up with dryer vent tubing and duct tape, you would be out like $9 then at least you would know one way or the other, something well worth it to know.
California98Civic 04-20-2013 04:59 PM
Did you use the search function for this site, in the above left corner? If not, do that first. This has been discussed many times. I think you're having trouble getting responses because it has been talked out so often. Here is just one search result I got: http://ecomodder.com/forum/showthrea...html#post22445
Read the whole thread and you'll see that the answer sorta is and has to be: "it depends upon your car and your driving conditions."
But do your own search. I can tell you that if you check my garage page, you'll find I linked to my WAI test under my listed current mods for my '98 Civic DX.
BTW:
That's what I have now.
james
