Old 04-20-2013, 03:43 PM   #1 (permalink)
Joe1234's Avatar
Question The effect of a cold air intake on mpg
I have a Civic VX that is completely stock. Will a cold air intake make my mpg worse all other things being the same? Anyone have test results from a similar scenario?
Old 04-20-2013, 04:43 PM   #2 (permalink)
I've always understood that warm fuel and cold air garnished the best results, but found that many will argue with me on these points.
I know nothing.
Experiment in an A/B fashion and post your results.
Old 04-20-2013, 05:27 PM   #3 (permalink)
Joe1234's Avatar
I would have to waste the money required to buy a cold air intake and the tons of time that would be required to get a decent set of results to know the answer. That's why I asked here first hoping that someone has already tried it.
The Following User Says Thank You to Joe1234 For This Useful Post:
Lovemy92vx (06-28-2015)
Old 04-20-2013, 05:39 PM   #4 (permalink)
I have a cold air intake - I don't think it matters very much; but that is just a WAG. Mine cost a lot and I know it was not worth the money.
Old 04-20-2013, 05:59 PM   #5 (permalink)
Rig something up with dryer vent tubing and duct tape, you would be out like $9 then at least you would know one way or the other, something well worth it to know.
Old 04-20-2013, 05:59 PM   #6 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Did you use the search function for this site, in the above left corner? If not, do that first. This has been discussed many times. I think you're having trouble getting responses because it has been talked out so often. Here is just one search result I got: http://ecomodder.com/forum/showthrea...html#post22445
Read the whole thread and you'll see that the answer sorta is and has to be: "it depends upon your car and your driving conditions."
But do your own search. I can tell you that if you check my garage page, you'll find I linked to my WAI test under my listed current mods for my '98 Civic DX.
BTW:
That's what I have now.
james
mcrews (04-20-2013)
