Old 08-02-2017, 05:55 AM   #1 (permalink)
My solar battery tender
For my MR2 I put in a Scorpion Stinger 7.8Ah lithium ion battery which weighs 3.6lbs thus shedding about 23lbs, but then I measured the standby current of the car and found that the car was drawing 48mA* while off, thanks to the aftermarket gauges and alarm. Since the battery shuts itself off after it reaches 5 or 10% charge (I forgot which), I essentially only have around 150 hours of standby time before I need to jump the car. I spent a few days pulling stuff out and sorting out some wiring, and managed to get the parasitic load to under 30mA by shedding some alarm stuff, but that's still not enough.
(For the record, if I had to do it again I would have gotten this battery for its higher capacity but at the time I didn't know the price was so good: LiFePO4 Prismatic Battery: 12.8V 20Ah (256Wh, 10C rate) with LED Balancing - UN38.3 Passed (DGR))
I thought about getting the Harbor Freight battery charger, but I was worried the regulator on it wouldn't be very good and it could possibly fry the battery, so I ordered some 53mmx30mm 5V solar panels off Ebay for 86 cents each, and put 3 in series with a diode, and taped it on my dash like so:
They claimed "40mA", which I thought was 40mA at 5V...unfortunately that was not the case. Open circuit voltage is 6V in bright sunlight, and I was getting around 28mA with the panels shorted out in direct sunlight, and under my windshield with direct sunlight it produces a little over 10mA when the sun is bright, so this charger unfortunately doesn't really put a dent in my battery drain.
The good news is that because I bought these individual 5V panels, I can resolder 4 of them together with bypass diodes and get 23.5V (the diode has around 0.5V drop) in bright sunlight, which will charge my 13.2V lithium ion battery at near maximum efficiency when it's bright out, and should provide at least some juice for perhaps 8 hours a day. Thus I ordered another panel for 86 cents and will be putting 4 of them together shortly.
If I were to do it again, I would buy 2 "12V" panels off Ebay (I think someone sells a set of 2 for 6 dollars right now), put them in series, and call it a day. The 12V panels are a good bit bigger, but it really doesn't hurt to have a net charge going to the battery during the day since it will drain it back down at night. Even then, those 12V panels are never going to overcharge the battery when any keyless entry system draws over 20mA.
I think any non-plugin hybrid car would be well served by this mod because always cycling the battery will hurt your wallet pretty badly by reducing the lifespan of the battery considerably, and the engine needs to work harder to recharge a dead battery. For 4 dollars worth of materials and parts, half an hour of soldering and such, then a bit more time to figure out the wiring, this is pretty low effort especially if you are familiar with how to tap into a constant 12V source in your car.
* As a disclaimer, I think my amperage readings are kind of wrong because my multimeter reads drastically differently between the 10A and 200m settings, so I think I need a clamp on ammeter for more accurate readings, but I think these are pretty reasonable estimates.
The Following 3 Users Say Thank You to serialk11r For This Useful Post:
Daox (08-02-2017), ksa8907 (08-02-2017), redneck (08-02-2017)
Old 08-02-2017, 09:18 AM   #2 (permalink)
Volt, gas only - '12 Chevrolet Volt Premium
90 day: 38.02 mpg (US)
Volt, electric only - '12 Chevrolet Volt Premium
90 day: 132.26 mpg (US)
Yukon Denali Hybrid - '12 GMC Yukon Denali Hybrid
90 day: 21.48 mpg (US)
I have considered something similar but for my kids ride on toys. They're all 12v so rather than plugging in 3 different chargers i could wire them all in parallel to a solar array. I have (3) panels that i have acquired, each is good for about 8 volts without load and around 1 amp.
A big benefit for you with those panels being such low power is no need for a charge controller. Even a slight discharge on the battery would take quite a bit of time to overcharge it.
Old 08-17-2017, 04:34 AM   #3 (permalink)
My 4th solar panel came in, again shipping surprisingly quickly from Thailand in under 2 weeks. Soldered it up and added bypass diodes on all of them in case there's some shade.
I also found a much better place to tap into constant 12V so wiring it up will be much easier this time around.
I'm hoping this will extend my battery life a bit more. The car has sat for about 1 week and is at 13.31V, which is fine, but it would be nice if it could go 2 weeks before reaching 13.3V.
Old 08-17-2017, 11:03 AM   #4 (permalink)
90 day: 29.78 mpg (US)
I don't think the solar panels are a good idea unless you have overcharge protection for the battery.
EDIT: Perhaps wire in LEDs/diodes across each cell to balance and provide some level of overcharge protection. I had a solar panel connected to supercaps that had LED balancers, but the sun was overpowering the LEDs ability to bleed excess charge.
30 mA still seems too high of a parasitic load. Do gauges really consume that much when the car is off? My vehicles are all down below 10 mA now.
I'd run the 20 Ah battery to avoid using the solar panels, which will probably overcharge the 7.8 Ah battery.
Old 08-17-2017, 11:58 AM   #5 (permalink)
cowmeat's Avatar
Princess Carriage - '20 Ford Explorer Limited
Silver - '22 Ford Maverick Hybrid XLT w/tow pkg
Maverick Hybrids
90 day: 41.3 mpg (US)
It would be cool to get solar panels the size of the windshield and use them as a sun shade, killing two birds with the same stone
Old 08-17-2017, 08:19 PM   #6 (permalink)
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
A single gauge can draw around 10mA in standby.
A new car can draw up to around 70mA (no aftermarket accessories). I get pretty tired of having to alway plug in each of my cars.
My Fiat killed (would no longer take a charge) it's 14Ah Life battery when I left it standing for a couple of weeks.
Old 08-18-2017, 01:39 PM   #7 (permalink)
The battery does have overcharge protection, at least it's advertised to have it. It is also advertised to have cell balancing built in.
However I don't think I need to worry about that. If I short the cells out when they're sitting in sunlight that brings them to maximum open circuit voltage, there's <40mA current. So at 14.2V they would not exceed 20mA, so the car could be sitting in noon sun constantly and be fine.
I tested it yesterday and to my pleasant surprise, the array measures >16V while the sun is about to set, so this is good. It should be providing at least 10mA for many hours a day, which should put a big dent in the parasitic current draw. I'll be watching the battery voltage closely to make sure nothing is wrong, but I am 99% sure it will still be drawing net current.
