Old 08-12-2009, 03:27 PM   #1 (permalink)
Effect of timing on fuel economy?
A while back I accidentally ran my Nova drag car at about 45 degrees of timing, locked out, from idle on up. It had race gas in it, and I was just cruising, so it didn't detonate, but a swear it got about 20mpg rather than the normal 8mpg. Don't know for sure, cause I don't have a gauge, just a fuel cell. Engine is a 355cid 12.5:1 compression small block chevy. Anybody else try running stupid amounts of off idle timing with any success?
1989 Dodge Diesel 972rwhp, 27mpg.
1971 Nova tubbed, solid cam 355 w/nitrous, 8mpg (sorry).
1960 Nash DIY Hybrid Project
Old 08-12-2009, 04:00 PM   #2 (permalink)
Manic Rabbit
Southcross's Avatar
Slow-n-Low - '81 Volkswagen Rabbit S
90 day: 33.97 mpg (US)
some engines just eat timing like its hashbrowns for breakfast... what really starts to hurt efficiency is at the top end of your RPM scale, the timing advances and becomes so early it actually tries to act as an engine brake by pushing down on the piston while its still on the compression stroke.
-Edward
Driven on Colorado roads, where NOTHING is flat
Present City 3x / Highway 4x
Goal: 4x / 5x
Old 08-12-2009, 06:47 PM   #3 (permalink)
2000 Civic EX - '00 Honda Civic EX
90 day: 36.97 mpg (US)
Send a message via AIM to ESmooth
What about on eco-driven cars that rarely see anything north of 3500 RPM?
Old 08-12-2009, 06:52 PM   #4 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
A lot of people will advance their timing just a hair to get one or two more free hp, but I'm not an expert and I'm not entirely sure it even works
Old 08-12-2009, 11:21 PM   #5 (permalink)
...beats walking...
...the 'original' Chrysler (Lee Iococca era) LEAN BURN systems actually used ignition "advance/retard" to accelerate/back-off the engine beyond idle.
...anybody remember this?
Old 08-13-2009, 06:47 AM   #6 (permalink)
toad - '84 Toyota Landcruiser FJ60 G
90 day: 9.84 mpg (US)
I'd say the OEM's would have already tried that.
You won't know until you do some partial throttle dyno runs.
Supposedly the magic number is that the mixture should reach full combustion/maximum pressure at 14 degrees after TDC. So you need to ignite the mixture at a point early enough that the mixture is all combusting at that point.
Fuel Economy related papers tasdrouille General Efficiency Discussion 41 03-19-2021 06:31 PM
smart cdi (diesel) owner from BC, Canada smartzuuk Introductions 29 09-06-2018 03:09 PM
Discussion on tire efficiency Ernie Rogers General Efficiency Discussion 69 12-27-2014 01:17 PM
mileage computer for a carbureted engine diesel_john Instrumentation 221 05-01-2014 10:38 PM
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 158 01-12-2013 11:59 AM
