EcoModder.com
-   DIY / How-to (https://ecomodder.com/forum/diy-how.html)
-   -   Electric Water Pump EWP80 (https://ecomodder.com/forum/showthread.php/electric-water-pump-ewp80-28008.html)
TexasCotton 01-20-2014 11:02 AM
Okay
We are familiar with Echo Troll(Canada) modifications. I have interest in the electric water pump . He went with a davies craig ewp80 electric water pump and installed in a TOYOTA. I am kinda considering modificiaton however have the following concerns:
space
mounting, mating , install in lower radiator space.
wiring connections.
do you remove belt driven water pump and if so how do you cover the new hole created.???
I like the idea of more engine torque and no belt but have concerns on how to get there..........
echo-francis 01-20-2014 01:43 PM
i will try to answer some of your question:
space: my a/c delete helped me on my echo but what car you have?
you will receve wiring instruction and mounting instruction if you buy the ewp
i did not remove my water pump. what I did is remove the impeller
California98Civic 01-20-2014 02:09 PM
Great thread idea. Subscribed. If there were a way to do this an make it reversible for emissions inspection, I would consider doing it. It's a great mod.
echo-francis 01-20-2014 03:28 PM
In my case it is not a reversible mod. But i dont Know why it Would affect emission ?
jeff88 01-20-2014 03:38 PM
+1 I've been wanting to do this since I saw echo-francis do it. Maybe this will give me the courage to do such a thing. (well, that and the money! :p)
I assume you mean not easily or worth the effort to have it reversed for an hour?
echo-francis 01-20-2014 04:19 PM
to reverse it I would have to but a new mechanical water pump and 2 new water hose and it would be very PITA
American Viking 01-30-2014 08:33 PM
Since Honda has discontinued a water pump design that fits about 500 of their motorcycles, and I went though hell finding one for a friends '97 vfr. After that 3 month crusade, I decided to look into replacing the Honda pump with something without a mechanical shaft seal.
I found that bosch makes a pump called the PAD pump that uses a mag coupled drive and only draws a few amps (less than the Craig pump). Its on my list of things to try on the HHO VFR, but its not at the top of the list.
http://www.bosch-ibusiness.com/boaaw...AL_DRAWING.png
gone-ot 01-30-2014 08:38 PM
Flow rate(s) vs. pressure(s)?
American Viking 01-31-2014 01:02 AM
I've got this chart, just remember most engine driven pumps don't move much water at idle.
http://www.metricmind.com/line_art/pad_performance.gif
gone-ot 01-31-2014 11:12 PM
...sorta *implies* the use / insertion of either: (a) metering plate/orifice or (b) adjustable value to control/limit coolant flow at engine idle, but not at full load conditions.
