Old 07-15-2009, 07:33 PM   #1 (permalink)
Yale electric forklift motor identification
I have an old Yale 3600 lbs forklift with a 9" x 14" (or so..?) electric motor. The forklift runs on 36 Volt. Before I take the forklift apart I would like to know if that motor can be converted for using in an electric car. That means it should run at least on 96V and should develop decent horsepower. Can anyone identify the motor based on the forklift(size) and some pictures I will try to attach?
Thanks, Bernd
P.S. Do I post in the right category?
ID:	3851   Click image for larger version
ID:	3852   Click image for larger version
Old 07-15-2009, 08:23 PM   #2 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
You can check the ID plate on the lift, call Yale, and they can tell you anything you want to know about that motor.
They can also give you information on any other part of the lift.
That would be your best bet for accurate information, but they probably won't tell you what aftermarket uses it has. Once they give you the part number and such, maybe even the serial number of the motor, you can probably just google it and find out what you need to know.
Old 07-16-2009, 07:15 AM   #3 (permalink)
Good idea! I will do that!
Bernd
Old 07-21-2009, 02:18 AM   #4 (permalink)
Did you manage to get any information?
Old 07-30-2009, 09:14 AM   #5 (permalink)
looks like the one I just got from a wrecker.I am going to put the big drive motor( 48 volts) in a 1995 metro 2dr. I got all the wiring and the contactors but I need a wiring diagram to figure it out.model #of mine is erc040ban48st077.any help apprecated.
Old 11-11-2009, 10:48 AM   #6 (permalink)
How about a forklift motor in a 94 Ford Probe using 144V? Brian Mathis' 1998 Ford Probe
Old 03-04-2012, 09:00 PM   #7 (permalink)
Thank you for the idea that you share all I really like to know more about forklift..
Sorry, new users are not permitted to post links in their signatures.
36v, car conversion, electric motor, yale forklift
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 1056 12-14-2024 12:21 AM
“Revenge of the Electric Car” Coming in 2009 SVOboy EcoModder Blog Discussion 18 03-28-2012 07:24 PM
100 mile range Ranger EV? Frank Lee Fossil Fuel Free 10 08-05-2010 12:09 PM
48 Volt Electric Forklift in Seattle! Intrigued For Sale 0 01-18-2009 03:57 PM
Electric Forklift in California Intrigued For Sale 0 01-15-2009 08:01 PM
