EcoModder.com
-   The Lounge (https://ecomodder.com/forum/lounge.html)
-   -   Elon Musk is donating the money for Flint schools to have clean drinking water. (https://ecomodder.com/forum/showthread.php/elon-musk-donating-money-flint-schools-have-clean-36923.html)
Xist 10-11-2018 12:27 PM
CNN: Flint schools are getting safe water fountains thanks to Elon Musk
In case you\don't believe everything you read: Fox Business: Elon Musk donates $480K to help solve Flint water crisis
I did not want to create a new thread, but when I searched for Flint, I did not see any references to its water. This does not seem like a permanent solution. Is anyone working on that?
oil pan 4 10-11-2018 01:55 PM
Put in a rain water cistern is the only semi permanent solution I can think of that could be done quickly.
Xist 10-11-2018 02:39 PM
That is a very good solution, at least until the lead pipes and other problems are fixed. Has anyone tried to do this?
Could Rainwater Harvesting Solve Flint’s Water Crisis?
oil pan 4 10-11-2018 02:59 PM
I'm buying a 1,000 gallon water tank any day now.
If it will work in NM it will work there.
Xist 10-11-2018 06:30 PM
I am sure that it would work most places, but I do not know how many people in Flint could afford $500 for the tank alone, but if they have gutters a 55-gallon barrel would be a start.
Unfortunately, that would not help people who live in apartments, but I am sure that it would not take long to pay off a $50 drum if you are going through ten gallons of bottled water a day.
oil pan 4 10-11-2018 09:18 PM
Yeah it will require someone else's money.
When this started there were people around there who said they didn't even have anything to put water in.
freebeard 10-13-2018 07:15 PM
I've got one of these setting out back on pier blocks
https://www.dudadiesel.com/img/items/275tote444.jpg
275 gallons/1000 liters. I think I paid ~$120.
oil pan 4 10-13-2018 09:17 PM
Yeah the "food grade" IBC totes go for around $100 used.
