EcoModder.com
-   Instrumentation (https://ecomodder.com/forum/instrumentation.html)
-   -   Engine Analyzer?? (https://ecomodder.com/forum/showthread.php/engine-analyzer-32649.html)
Isaac Zackary 08-27-2015 02:23 AM
Engine Analyzer??
Anyone use one of these on a car? It would be handy for lean burn operation. Or would this be considered overkill? Of course a fried engine wouldn't be the best thing in the world either.
JP Instuments - JPI EDM700-4C - Engine Data Monitor700 - Chief Aircraft Inc.
gone-ot 08-27-2015 02:16 PM
Sounds like a Scangauge II™ for aircraft...but the co$t of adding all those additional sensors will be high!
Isaac Zackary 08-27-2015 07:47 PM
Isn't the Scangauge II for vehicles with OBD2? My ol' 1971 VW doesn't have OBD2. Actually, it didn't even come with a temperature sensor! My other car, 1985 Golf has mechanical injection. But in an attempt to get the highest compression, leanest AFR and most advanced ignition timing it would seem advantageous, at least from an experimental and scientific view point, to be able to monitor all 4 individual exhaust temps and all 4 cylinder head temps. Now if only I had an aviation carburetor that I could adjust the AFR from inside the cabin. :D
