Engine bay aero?
OK, we all know that the engine bay is very dirty aerodynamically.
In most cars we can't avoid passing some air there. We also can't make the flow there clean, far from that. The question is: Can we make the airflow cleaner than otherwise? Cleaner enough to be worth the effort? |
What let's air out can also let water spray filled with road salt in.
This will corrode the electronics. However, it may take many years to do this. Today's electronically dependent cars have design measures to avoid this, most designs over 20 years old do not - in my opinion. Think twice before you let the devil in. |
I've been thinking about fabricating something to cover the rear well area to prevent salt from getting in. What's wrong with air exiting underneath the car? Seems like the airflow under the car would keep the exhausted air flow attached.
I don't think I get salt in from the rear/bottom, but the tires throw salt all over the catalyst when turning, which is probably why they rust so badly. I could also see salt affecting the coil packs on the back of the engine. |
The Dasher has a rat's nest of hoses and cables and wires. More modern cars have coils right next to the spark plugs and covers for the bumpy bits. Look for show car engine compartments, the have flattened firewalls and hidden wiring. Most of the internal drag is in the radiator itself. |
engine bay
*over the years,automakers have improved on that,with fake grilles,active shutters. *the 1963 Walter Korff' Chrysler Charger Daytona cooling system would cover the inlet portion of drag,with it's 1/6th-height grille inlet,and fully-ducted passage to the radiator. *to reduce from there,you'd have to fully duct the extractor portion,with contoured tuned outlets located at low pressure regions on the body.Ferrari has spent over $100,000 to develop a working system such as this.For one specific car. ------------------------------------------------------------------------- The lowest drag cars are electrics,with virtually zero cooling systems,or ICE vehicles,with closed fronts,and rear radiators of integrated,aerodynamically-tuned design.Again,$hundreds of thousands. |
I think on your own front engine car, the best you can do if you have a really big grille would be block part of it off and make some ducting for the radiator right? It would be very difficult to tell how the air flows through the engine bay and modify fenders or the hood accordingly.
