Engine load
It was recommended to me that i get two scangauges instead of two mpguinos because of the extra features but im wondering if those would be helpful to me and worth spending $200 dollars extra for my families two vehicles.
He said that the scangauge displays engine load and thats one of the most important thing to watch. Why doesn't the mpguino display load? isnt that proprtional to the amount of fuel being used??? I can get my engine trouble codes read for free at the auto parts store. my dash gauges already display coolant temp and the voltage though the later could be displayed with more resolution. Why doesnt the mpguino measure voltage? not enough ADC? Should i know intake temperature manifold pressure igninting timing or if the vehicle is in closed or open loop? How does that help me? Would i need to know that to drive more efficiently? maybe knowing the pressure would let me know when to change the air filter or something. I dont know if any of those features would be usefull for efficiency or maintenance. Does the mguino not have the ability to take trip averages,(assuming averages can be helpful).? -mike |
All those data points (MAP, water temp, oil temp, etc) might be useful for analysis if they are logged along with your speed & MPG, and analyzed later on your PC; but i dont see how one can read those values real-time to optimize your driving habits. Even if you could (and manage to drive safely), your wife/kids surely cannot.
Best thing for the family members is a simple "This is your MPG" display, so they can ease up on the gas & instantly see results. Also, if you are the bread-winner & buying all the gas, they might not care about MPG (but lucky you if they do). As for your question about why MPGuino doesnt display all that other data... yes, limited ADC, plus each signal needs to be wired. 'Guino only requires 4 wires, one being ground, so it's nice and clean. if you want all the other data, maybe you want an OBDuino instead? Looking at the schematics, it looks like a hybrid MPG/OBDuino could be rigged. I just bought my first OBD2 car (98 tdi), so i might try it. I'd like to be able to probe the OBD port for the ancillary data, but for MPG, i'd rather keep the MPGuino method of reading the injectors, than blindly trust what the OBD thinks my MPG is. My concern about building the OBDuino, though, is availability of the transceiever chip, mc33290, or equivalent. |
Daox said he watches engine load more while driving than mpg. Thats why i was wondering if it was important.
Yeah i think alot of that other stuff may be more usefull for diagnostics than mpg. My father drives a 2001 tundra so hes more concerned with gas than me lol. Measuring battery voltage wouldnt require an extra wire since the mpguino is already powered by the battery lol, thats why i was wondering if you ran out of ADC. |
I should have clarified. I mainly use pulse and glide technique. It involves accelerating up to speed and killing the engine to coast in neutral, then bump starting with the clutch and accelerating again. It is a fairly advanced technique, but accelerating at higher loads still runs the engine at the highest efficiency points. I use this acceleration method if I am using P&G or not.
If you are planning on getting two meters, I'd get one of each. The SG is very easy to swap between vehicles, and the mpguino can be as well (you just have to wire both cars with a connector so it plugs in). |
I think load feedback is important too, but it is "calculated" from lots of vehicle specific data and sensors. It is sorta what I'm getting at with tracking the change in acceleration over the fuel flow rate: http://ecomodder.com/forum/showthrea...tml#post176541
It would be a rather arbitrary number, but when it peaks you are accelerating most efficiently. re: batt voltage. There's 2 adc left. With so many options (map,maf,throttle position, various temps, a piezo?, 02 sensor, battery voltage, ???) and none the same on every car, it is a challenge to know what precisely to do with those ADC ahead of time. You are certainly free to experiment, I'd be most interested in whatever helps w/efficiency. Battery voltage could be nice when I'm sitting with the engine off but with an electric load, but if you have a wideband o2 sensor, well you can "reverse engineer" lots of values. I think I might add a generic "gimme a reading from adc1 or adc2" option at some point, but without knowing what it is reading, or what it means, it will be hard to integrate into other computed values. |
The single most critical load indicator is manifold vacuum, or in the case of MAP which is atmospheric pressure minus manifold vacuum.
This can change considerably at most throttle positions depending on the speed, gear, and grade the vehicle is negotiating. If you are at the lowest possible manifold vacuum reading without full load enrichment, you are in the best position as far as BSFC is concerned, as long as you are in the proper (read fairly low) RPM range. Once you get the feel for this load range, then you have to calculate which gear will be best for acceleration to your peak speed. As a general rule the highest practical gear is usually the best selection. The exception will be when you are climbing a grade and need to use a lower gear to maintain a speed up the grade. In every case you want to avoid absolute WOT and fuel enrichment, unless it is necessary for avoiding an accident. Install a vacuum gauge temporarily and learn the best throttle positions to maintain your vacuum around 2 inches of less without WOT. After a while it will become second nature and you could remove the gauge. regards Mech |
...or, you can "read" the MAP value from your SGII (if you have one) and acomplish basically the samething that Old Mechanic recommends.
miket, if your vehicles are OBD2, I suggest you look at Magister's ODBuino. I have one in my wife's 08 Avenger, and it does display eng load, along w/inst mpg and several other parameters...
Oh now I understand, how load or map will help with acceleration whereas instantaneous mpg wont help, at least not directly.
Does the OBDuino read the injector pulses for accuracy or does it rely entirely on OBD which i heard is less reliable. How much does the obduino cost and is there a kit? I can solder surface mount if need be. Money is tight right now so if a save a few hundred over buying two scangauges i'd be happy. Hmm daox, it did not occur to me that i could put a connector on a mpguino and switch it in and out of a vehicle like i would able to do with a scanguage or obduino. |
I think obd is quite accurate enough for the majority of drivers, but it does have it's problems:
1. OBD isn't much of a standard, it is actually many standards with a convenient name. It takes a lot of circuitry (cost/bugs) to be able to reliably plug into an obd connector and expect to communicate. Even then when different folks made the computers for the different cars, they made different interpretations and assumptions, and you sometimes see bogus data on the port. And also it is limited to 1996 or newer. 2. All the mpg parameters have to be inferred and polled and be based on assumption, introducing room for error. 2.a. fuel used, this is based on maf (if available) or map * rpm. But it assumes that the engine is at stoich (14.7:1) so that if it is cold, or enriching, or lean burn, or diesel or ??? then the fuel used can be off . 2b. for distance, it has to periodically ask the car computer "how fast are we going", and remember when and what the value was the last time it asked, and guess at the distance traveled from there. 2c. polling is less accurate also as there is a window for peaks or valleys to get in between polls, the guino gets an interrupt when an injector opens and closes, and when the axle makes a vss tick. It doesn't have to rely on the computers vehicle specific interpretations of what the injectors and vss are doing, it goes straight to the source of the info. There are some chips (i.e. elm and other projects) that help with obd connections, but they still take a lot of support circuitry to be able to connect to any obd car, far more than the guino has. But you do get "interpreted" access to pretty much all the sensors on the engine once you sort out the obd connection issues. Having all those sensor readings handy is fun, but the key ones for accurate mpg are how long have the injectors been open and how many vss tics have happened, and those can get a bit muddled in an obd system. |
02 tundra and 01 maxima both use ISO-9141 OBD2 protocol.
How much would a kit cost me? How big would the obd2 inacuracy be for those vehicles for DWL, P&G, or trip/tank average? Does the ethanol fuel or the winter/summer mix mess things up? |
I don't know if the ISO is a kit, here is Mags first version of ISO built with an arduino, an LCD and an extra chip for ISO communications, not too terribly complicated if you can figure out an arduino:
OBDuinoDiagram - opengauge - Whole diagram of the Arduino board, LCD, interface - Project Hosting on Google Code here is the original obduino arduino source code (pde) and txt notes. opengauge - Revision 167: /trunk/obduino you are in for a lot of work if you are new to this sort of thing. Edit: But having these little chips at your command is worth a lot too... I use 'em for everything from vehicles to water softeners. |
If the odb is actually less accurate than the mpguino method of reading injector pulses im sure i could combine them to make a hybrid. The obdguino has several unused pins. I do have some other ideas that would use those though.
Can a Barebones board arduino or a Really barbones board arduino work? Im not sure where to get that ISO chip. |
a regular arduino board will work. Looking at the OBD schematic, it should overlay perfectly with the mpguino, hardware-wise, as there is no conflict between OBD's use of TX/RX pins, and MPG's use of Injector/VSS inputs.
If you intend to dual-function the arduino, you will definitely need a 328 chip. 168 has too little memory. Also, to reduce pin usage for other functions, you could buy a 74hc164 chip for $.50, to allocate 3 fewer digital i/o pins to the LCD. |
What about using an arduino mega? More input/outputs for doing what you want.
problem is that the obduino and mpguino both have gotten away from arduino for production and there is plenty of non-arduino chip specific code in there. mpguino was already a bit much for arduino as an experiment. A new chip like in the mega will be work/testing/etc, plus all the fun of watching your stuff break with each new arduino version. I'm not volunteering to run another arduino based chip neutral effort for this sort of demanding application :)
i recall someone having trouble running this on a mega, due to massive pin reassignments.
can anyone tell how to properly assess LOD in scale of vacuum gauge? I mean i.e. what values should indicate vacuum gauge when LOD is 75-80%? Is it the yellow field (from 10-5 In/Hg) or maybe lower? Thanks |
dunno, here is me reading a map gauge at different pressures
http://ecomodder.com/forum/showthrea...nsor-5208.html I would wang open the throttle and note the reading at different rpm readings to figure out the 100% line/curve then interpolate from there. |
MAP = Baro - intake vacuum
MAP = ambient Baro - intake vacuum
MAP = Manifold Absolute Pressure MAP and Intake vacuum are NOT as useful as Calculated load or Engine Load systems that are speed density systems (that use MAP sensors) still have a flow PID a MAF value even though it is calculated not measured - OBD 2 generic has a MAF PID even when the system is a speed density http://farm3.static.flickr.com/2481/...aa23e08b_b.jpg the PID is there , the scan tool may or may not see it , the scan tools you have referred to so far are tinker toys and should NOT be used by anyone serious about doing this kind of thing imho this scan tool OBD-2 Vehicle Explorer Scan Tool Browser is not a tinker toy and it costs LESS then scan gauge 2 no i do not own one nor do i have any thing at all to do with alex pepper yet if i was beginning , that would be my first scan tool Calculated Load or ENGINE LOAD can be used to determine how well or poorly your modification really works , repeat conditions and note change in Calculated Load , graphing is better http://farm6.static.flickr.com/5128/...4be1cc34_b.jpg at WOT wide open throttle calculated load on an NA engine should reach 100% it never does , but it should be close - modifications that restrict flow and output will show in max available calculated load , like the image above 60% calculated load would be an UN improvement , a failure , but you do not have to guess - you can test . Measuring intake vacuum at hot idle is another way to test flow the higher intake vacuum is at idle , the better the engine flows , 20" on most engines is "good" test your own engine to see . turn on hi beams , watch vacuum drop , turn on AC , watch vacuum drop - intake vacuum is NOT an accurate way to predict LOAD OR Fuel consumption at a certain load or rpm . Calculated Load is |
What is on the horizontal axis on the VE chart? What scale?
Also I assume the second picture uses seconds on the horizontal axis. |
STFT or real time Fuel trim MUST be close to 0
http://farm6.static.flickr.com/5058/...6c2b9636_b.jpg
for the calculated load PID to be accurate real time fuel trim MB 33 on VW Audi OR STFT short term fuel trim OR fuel trim on the front 02 sensor on America or Asian must be within +/- 5% from zero at WOT , wide open throttle and at idle and 2k rpm MB 32 on VW Audi or LTFT long term fuel trim (American / Asian) MUST also be +/- 5% from zero ================ intake vacuum is useless for this - the car above has either Under reporting NEW MAF sensor OR restricted fuel delivery , based on Calculated Load at 80% at WOT with real time fuel trim adding over 15% at WOT . test do not guess - graph or log the data to play it back do not attempt this with tinker toy scan tools - they can not do it. OBD-2 Vehicle Explorer Scan Tool Browser this is the cheapest real scan tool Escan is better AutoEnginuity is very much better. VCDS is outstanding for VW Audi and has ISO 9141 2 , OBD2 generic for lesser cars vacuum is only a portion of the load calculation , Calculated Load or ENGINE LOAD is the sum total of all the LOAD PIDS as processed by the ECM in real time . fuel delivery is determined by CALCULATED LOAD or ENGINE LOAD .... not intake vacuum |
i would have to log it to see Horizontal time
which i did not do and usually do not do , i just grab a screen cap after the WOT pass , which lasts from about 20 mph to about 65 mph in as long as it takes the car in question to cover that change in speed at WOT ..... the data a cruise before and decel after is also included . the AE info was logged , then played back, same thing i could look up the time in the csv file to see , but it really does not matter , i am looking for peak values at WOT ... most of the time. |
MPGuino works well BUT it is not a scan tool
i have an MPGuino on my steering column , it works very well to display real time FE and trip FE along with the other things it does , on an OBD2 car a Geo Metro. the VW and Audi have real time FE things in the factory instrumentation . i do NOT use a vacuum gauge excepting when testing engine condition imho for most cars for most users in it's present form the MPGuino is the best bang for the buck to determine real time and trip fuel economy even if the car in question is an OBD2 car it is a KISS (keep it simple stupid )tool and it is outstanding |
