Old 09-22-2008, 10:24 PM   #1 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
Reading a MAP sensor
Here's my notes on experimenting with a map sensor on the bench with a brake bleeder pump and a duino. using a 5 volt reference.
inches of mercury, pin value
ambient, 762
3, 667
5, 619
8, 543
10, 493
14, 390
~25.18 units per inch
Map pinout (your sensor may be different)
Code:
connector  _________
front     (_________)
            A  B  C
           +5  -  Signal (on analog 1)
looks pretty linear till you get near ambient. The cheap gauge on the pump probably has a lot to do with that.
Code:
int mapPin=1;
void setup(){
  Serial.begin(9600);
void loop(){
  Serial.println(analogRead(mapPin));
  delay(500);
Old 09-17-2010, 11:12 PM   #2 (permalink)
cmj
Honda - '96 Civic EX
90 day: 36.12 mpg (US)
If you don't mind, I'll be adding my .02 to this thread very soon!
Old 09-18-2010, 01:58 PM   #3 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 57.08 mpg (US)
CM400E - '81 CM400E
Whatcha thinking about doing with map sensor info dcb?
Old 09-18-2010, 04:00 PM   #4 (permalink)
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.85 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 28.75 mpg (US)
...a computerized VACUUM gauge path toward realtime BSFC?
Old 09-18-2010, 10:49 PM   #5 (permalink)
dcb
needs more cowbell
dcb's Avatar
looking around it seems like there might be different map sensors in circulation, so folks would probably have to borrow a vacuum gauge and pump to do their own calibrating.
Old 09-19-2010, 06:13 PM   #6 (permalink)
...beats walking...
...both of those plots look very linear to my eyes!
...what R-squared values do you get--three-9's or better?
Old 09-19-2010, 06:27 PM   #7 (permalink)
dcb
needs more cowbell
dcb's Avatar
yes linear, but different all the same, you still have to figure out your own personal slope and offset for the map sensor in your car if you are looking for absolute numbers. Of course as a "beat your own high score" semi-arbitrary indicator then it is fine.
Old 09-19-2010, 08:29 PM   #8 (permalink)
...beats walking...
...it looks like a "normally aspirated" sensor (blue) vs. a "supercharged" sensor (pink) to my eyes.
...and, both are 'full-scale' max'ed at 5.0Vdc.
Old 09-19-2010, 08:44 PM   #9 (permalink)
dcb
needs more cowbell
dcb's Avatar
feel free to research it It may be that there are only a couple slopes and offsets in practice and that you can make a good guess by taking an engine off reading.
Old 09-19-2010, 10:22 PM   #10 (permalink)
Red CBR - '011 CBR 250R
90 day: 74.21 mpg (US)
99 MAX - '99 Maxima GXE
90 day: 28.35 mpg (US)
Vulcan - '05 Vulcan 500 LTD
90 day: 56.4 mpg (US)
If you know the MAP, RPM, and fuel consumption, shouldn't you be able to map BSFC for any engine?
regards
Mech
Best spark plugs / wires with FE in mind? noopy7 EcoModding Central 12 10-29-2010 04:18 PM
My Kingdom for a NOx Sensor cfg83 EcoModding Central 19 08-25-2010 07:55 PM
VX Info...WARNING: lots of info! TomO Off-Topic Tech 1 01-05-2010 01:39 PM
Oxygen sensor gauge reading at wider throttle openings markweatherill Instrumentation 4 08-28-2008 06:18 PM
MAF sensor life Daox Off-Topic Tech 9 03-25-2008 03:29 PM
