Engine off coasting?
How long do you need to coast before you actually gain increased mpg? Engine off for more than 6 seconds? At what point does it actually cost more to start (fuel enrichment) the engine back up vs just engine on coasting?
It depends on how long and how hard you used the gas pedal before you started the coast, and how long your trip is. Typically with a Scangauge or Ultra-gauge, you'll see immediate mpg gains when you start coasting, within a block or two. Get instrumentation like that, and eliminate the guesswork.
If you bump start does it change the mixture? (Specifically Mazda F2 engine)
I have heard that the engine if left off to long (eoc) then when fired back up the ECM goes into fuel enrichment ... I am not sure..just curious..
5 miles is a long coast, those are definelty worth turning the engine off, but for anything under 30 seconds i don't think it's worth turning the engine off
Similar question: What's the shortest time where turning off and re-starting your engine is a net gain over idling? Or, at what time is it the same or better to idle, if any?
The automotive pundits say 7 seconds is the magic number with modern fuel-injected cars. Shut your engine down at any stoplight where you'll be idling >7 seconds. You'll use less gas to restart it than you'd waste idling. The EPA says $.17 of every gas dollar is wasted idling.
Thank you. Now does that figure change with kick-starting?
