Engine off coasting on my matrix
I want to be able to coast with the engine off but leave the ECU, dash, & scangauge on.
From my searching it looks like what I need to do is make a kill switch for my fuel injectors. I went digging through my low voltage scrap wire box and found a 12v 40A relay that came off a HID kit. It is designed as a normally open circuit but I think I can make that work bu using a normally closed momentary switch. My issue is finding the Injector fuse, any idea as to which one that might be on a 2006 Matrix? All I saw in the fuse box that might be it was a 20A EFI fuse and a corresponding EFI relay. No hint as to what EFI stands for. Ideas? Hints? |
Yeah, that dash reboots slooow...
EFI is electronic fuel injection, but that circuit seems to contain a lot of stuff normally, likely the computer that controls all the dash stuff. |
The dash does boot slowly.
There is a EFI 2 (15A) and and EFI (20A). Which one does what? |
Take the fuse out and see if the car starts.
that might work, but it will not tell me what else is on the circuit.
I did some searching for wiring diagrams. I found one for a 2003 matrix, my 06 should be similar but not exactly the same.
Anyone want to read these and give me a none EE description? What does the EFI fuse do? If these do not help I have 20 other pdf to sort through. Page 1 http://i835.photobucket.com/albums/z...3at71530PM.jpg Page 2+3 http://i835.photobucket.com/albums/z...3at71534PM.jpg 4+5 http://i835.photobucket.com/albums/z...3at71543PM.jpg 6+7 http://i835.photobucket.com/albums/z...3at71547PM.jpg 8+9 http://i835.photobucket.com/albums/z...3at71554PM.jpg Thanks! |
If I put it back to II too fast, even the engine will come back on ! |
Dash does but I do not like power cycling the ECU. I do not think that the SC comes back on (or it takes a while).
All I do with my Vibe is to stick it in Neutral, turn the engine off with the key, wait a few sec's turn the engine power back on with out hitting the starter and coast. This way I still have power steering while coasting, then bump start it when it necessary. My ScanGauge is in Hybrid mode so that stays on, car will coast quite a way.
Neddy |
