Old 07-12-2022, 12:12 PM   #1 (permalink)
The Mistress - '88 Bmw 320i Touring SE
Team m8
Last 3: 27.17 mpg (US)
Germany Beadle - '91 Mercedes 300td (estate, N/A)
90 day: 24.63 mpg (US)
The Bloodylingo - '05 Citroen Berlingo Multispace Desire
90 day: 39.77 mpg (US)
Shanner Scaab - '03 Saab 9-5 estate Vector
90 day: 26.19 mpg (US)
Clio 182 - '05 Renault Clio RS 182 182
90 day: 31.73 mpg (US)
320Touring's Renault Clio 182 - A different approach to Economy in the UK
Hello,
This came up for sale in October last year as a non-runner. viewed it and got it started on the sellers drive in under a minute, by resetting the immobiliser.
Since then I have done about 6400 miles in it, with it almost daily use.
It had to have some brake work for the UK MOT, and has also had a clutch replaced (was slipping when I bought it), other than that it plods along ok.
What is it?
The Clio is a compact car, generally found with 1.1-1.6 L petrol engines, or 1.5 Dci diesels. The Clio 182 is a development of the basic car, with a tuned version of the 2.0 16v F4r petrol engine out of the Renault Laguna (Renault's large family saloon)
In the 182, the engine makes 182bhp, and 147lbft of torque, delivered via a 5 speed manual gearbox driving the front wheels.
1t weighs in about 2300/2400 lbs depending on trim and options.
Its a light weigh hot hatch with enough power for about 140mph, that will seat 4 and take their luggage, and easily fit in a standard parking space.
Its also very French and flakey - most weeks something needs fixing, but its worth it for the driving experience
Why are you using it for economy?
Its really light
Its the most modern car I own
It has DFCO
Manual gearbox
Fuel injected
Relatively cheap
Easy to get parts for
Has cruise control (a licence saver)
Good at conserving momentum due to good handling
Pictures
It's also going to be used for hillclimbs/trackdays and drag racing as it would be rude not to! This was the result on the drag strip, just before the clutch failed a week later
Modding/Maintenance options (remember I'm in the UK, so cant get away with Kammtails /rubber skirts etc)
Engine
Oil Service
Coolant Change
New spark plugs (they have a 72k mile service interval)
Injector spray check/ replace as required
Warm air intake
Suspension
40mm drop on sports springs?
new dampers
Wheels and Tyres
Move from 16" to 15" wheels
Fit tyres with better economy rating than current than current
Underbody
Identify potential areas for underbody cleanup
I'd be interested to hear if you have any suggestions on how I could improve the efficiency over and above the mods I have listed above..
ID:	32596   Click image for larger version
ID:	32597   Click image for larger version
My Blog on cars- Fu'Gutty Cars
http://fuguttycars.wordpress.com/
US MPG for my Renault Clio 182
The Following 2 Users Say Thank You to 320touring For This Useful Post:
freebeard (07-12-2022), Joggernot (07-13-2022)
Old 07-12-2022, 07:10 PM   #2 (permalink)
Team m8
I had some issues with the picture hosting, all sorted now
Old 07-12-2022, 10:03 PM   #3 (permalink)
Thanks for that. I'd have pointed it out but I didn't have a solution. What made the difference?
Old 07-13-2022, 03:27 AM   #4 (permalink)
Team m8
I just re- uploaded the pictures to the original post..
The Following User Says Thank You to 320touring For This Useful Post:
freebeard (07-13-2022)
Old 07-13-2022, 09:25 PM   #5 (permalink)
Sure it's a cool pocket-rocket.
320touring (07-14-2022)
Old 07-14-2022, 08:58 AM   #6 (permalink)
Team m8
It is, but not as cool as I would like cos the A/C doesn't work
Old 07-16-2022, 01:03 PM   #7 (permalink)
No A/C sucks sometimes. On a sidenote, what about trying to use that moisture taken out of the interior by the A/C for a supplemental water injection?
Old 07-23-2022, 08:04 AM   #8 (permalink)
Team m8
I think we're a fair way away from that at the moment. Just trying to get it to a good base just now. But an interesting suggestion
On that note
Tell me you have a ****ed rear bearing without telling me... Spacer washer ****ed too, will order spacers and discs now. A spare disc is on and grumbling gone. Technical success.
Old 08-23-2022, 04:05 AM   #9 (permalink)
Team m8
This has mainly been doing commuting duties for the good lady (whilst her mk1 golf gets new injectors)
However, I had the opportunity to go and see my friend who has just opened a campsite on the Isle of Gigha.
The road to the island is a decently twisty, fast flowing road, and the closer you get to the campsite, the lighter the traffic.
I took the opportunity to run the 182 down and back - sticking to speed limits, but enjoying the roads.
The car is great for this sort of drive - you can leave it in 5th and tickle past slower moving cars, or shift to forth if you need to be nippy. Holding 60 is possible on a light throttle and engine braking is aggressive enough to allow attacking the corners with no energy lost to heat from the brakes.
On the way down, I was hauling grain for the island brewery - about 60kg. The boxes were too tall to fit in the boot.
The ferry across is very picturesque
And the campsite is handily just next to the ferry slip
Home for the weekend was set up
The the island was wandered
On the way back, I took the opportunity to get a picture at a cool old garage in Inveraray
All in all, a great weekend away - with the added bonus of a best ever tank over 370 miles!
34.57 mpg (US)
41.53 mpg (Imp)
I expect I'll be back down again, so will see if I can better that
ID:	32785   Click image for larger version
ID:	32786   Click image for larger version
ID:	32787   Click image for larger version
ID:	32788   Click image for larger version
ID:	32790   Click image for larger version
ID:	32791   Click image for larger version
