Engine options for a CRX
The Used Oil Analysis for my CRX came back with bad news. Some lead, like last time, but more of it. Plus copper, which is probably from the backing of the bearings. Which means I need to fix or replace the engine relatively soon.
Since it's a 1990 CRX, I have about a zillion options for what I can do. Some swaps (like those from a car earlier than 1990) are out, but that still leaves most of the D- and B-series engines as swap candidates. Or, of course, I could try to rebuild the stock engine myself. Simpler swaps are better in general than complex ones, but there are certainly interesting possibilities that are complex. So, what would you do if it was you? [Trying to set up a poll.] -soD |
would you please elaborate on your used oil analysis for those of us that don't know?
I can't belive I got the first vote, I'm reminded of he that is without sin cast the first stone.
Go lean burn.................with a intercooled turbo!
What about an electric conversion?
Diesel. A mechanical injection diesel will be a really easy swap, you just have to male an engine mount and adapter plate.
If you use a vw engine, you need a rwd/scirocco clutch set/flywheel, and you stick the civic friction disc between them. |
If it ain't knocking or smoking, take care of it and keep running it. It might go for a long time yet.
To give you some idea of how much wear they're showing, the iron levels are 40 times the average for all oil samples. The lead is 12 times the average. The copper is 3 times the average. Chromium is 4 times the average. The levels of all are up quite noticeably from the previous oil changes, as well. (4x as much iron, for example.) I don't think a diesel swap is in the cards for MB. I'm just not competent to do that much work myself, and I can't think of a shop locally that would try it. Electric swaps are out of the question because I simply do not have a place to plug in! My wife's car gets the garage, and there are no outlets close enough to the street for me to access. So far, people seem to like the notion of putting a lean-burn engine in and finding a way to make it work. I figured that would be the most popular answer around here. :D -soD |
