engine pulley question
I was thinking i was gonna take off my air conditioning (to get a boost in mpg of course) but i was looking and unless i can somehow reroute my belt i would get rubbing from the other pulleys. The factory engines that didnt have a/c had an idler pulley. would replacing with the pulley still give me a eco-boost since there wasn't a load (or as much anyway)? I have a 95 astro
it wont let me put links or images since this is my first post but if you google "ac removal astro" then a thread on removal comes up with good pictures.a/c is on the top right. |
Best thing to do in this case would be to unplug the power to the compressor clutch. Some vehicles the A/C is always cycling on when you figure it wouldn't be.
The belt driving the unloaded compressor is very efficient, I don't think doing at that work to remove/bypass it would make a measureable difference. |
so if i just unplug the electrical connection then it should free spin continually correct?
The A/C should be free spinning when its off.
Unplugging the clutch assures it. Some vehicles cycle the A/C on briefly every minute or 2 for no apparent reason. |
Some vehicles, like mine, have a dedicated fuse for the AC compressor clutch. That fuse is currently removed.
