Enlighten me about a Prius + four.
OK, I've gotten so "fed up" with GM's lack of 'customer service response' (lack there of) with our 2011 LTZ Cruze that we're seriously considering dumping it and moving on to a 2013, 2014 or 2015 Toyota Prius...but we've never considered a Prius before.
So, in no particular order, here are some of my questions: 1) What is the typical battery-pack life? 2) Is battery life driven more by usage (miles), temperature (hot/cold), or what? 3) How leather-like is that faux-leather "Softex™," which is really just expanded polyurethane plastic (and they want an UP-CHARGE for it?) 4) What brand are the OEM P195/65R15 tires and are they LRR? 5) How accurate are the dash gauge MPG readings? 6) How accurate are the dash gauge BATTERY readings (%-left, range, etc.)? 7) How safe is their Smart Key System: "...may interfere with some pacemakers or cardiac defibrillators"? (I have one) 8) How well do the 'heated front seats work? What effect on battery life? 9) How visible/useful is the Heads-Up Display (HUD)...especially in sunlight? 10) How many problems with the Multi-Information Display (MID) unit (screen & electronics)...touch screen? 11) How effective is that battery-powered AC in hot summertime & at stoplights? Oh, also, what Prius website(s) should I visit? |
I have an 05 prius so cant help you with the newer ones, but PriusChat can
Did you run the numbers to see if this makes financial sense? Since the Insight has been discontinued you should be able to get a much better deal.
Long story short hybrid hate hot weather over 100 degrees as it shortens the battery life and most limit warranty in hot states. Second, they hate to be parked. They must be driven weekly if not daily or the battery life is shortened. Cold weather cuts your mpg by at least 20mpg and the more heat you use the less mpg you will see. |
Some answers, but others might have more to add:
1) What is the typical battery-pack life? Don't know about the US, but in the EU we get 10 yo. warrenty on the Hybrid drivetrain 2) Is battery life driven more by usage (miles), temperature (hot/cold), or what? It is NiMH batteries, which are very durable, så don't worry about them. Also system takes great care of them 5) How accurate are the dash gauge MPG readings? In my yartis within 5% 6) How accurate are the dash gauge BATTERY readings (%-left, range, etc.)? You don't need that information 7) How safe is their Smart Key System: "...may interfere with some pacemakers or cardiac defibrillators"? (I have one) In my opinion the smart key system is useless, and eats a lot of power, fo stay away 8) How well do the 'heated front seats work? What effect on battery life? Belive they run on the 12 V batryry, and they heat well, almost too much. Dosent use them. |
I think the stock battery usually lasts as long as the Prius does. Even in the 1st gen Prius. The on dash MPG readings are a bit high sometimes, but that may depend on the tires.
It's a hybrid, so the battery gets charged and discharged multiple times during a trip, depending on the trip. The 3rd gen has an EW Mode button that keeps it in electric only mode - until the battery depletes and then the engine comes on and charges it. Regen also charges it. I can't think that the Smart Key does anything like that - it has to pass FCC regs and I'm sure it is safe for a pacemaker. It (probably) works on the same frequencies as any typical remote key fob. I can't speak to the heated seats. |
FWIW, these are just some of the questions the local Toyota salesman was NOT able (or willing?) to answer...hence, my bringing them up here.
Well, we did it -- we dumped the 2011 Cruze and got a 2014 Prius-4 today!
Although we really wanted a Plug-In Prius (PIP), there were none to be found in AZ because (apparently) all the AZ dealerships just 'gave-up' on trying to sell them after '12 & '13 dismal sales. |
