EcoModder.com
-   -   EOC and non flat-towable car - any way to fix? (https://ecomodder.com/forum/showthread.php/eoc-non-flat-towable-car-any-way-fix-17984.html)
katiep 06-30-2011 02:30 PM
I want to know if there is any way to modify a car so that one that can't EOC would then be able to EOC without resulting in damage.
Daox 06-30-2011 02:38 PM
It will take some research and a fair amount of work, but it can probably be done. You need to tap into whatever passage is used to oil the transmission components and add an electric oil pump to keep oil going to the transmission bits. You'll also have to come up with some way of turning this pump on and off.
TheEnemy 06-30-2011 02:53 PM
With an electric pump, use a relay tied to the ignition or accessory power.
hamsterpower 06-30-2011 03:02 PM
Swap in a manual transmission. I believe most manuals are flat towable. At least enough to EOC.
Phantom 06-30-2011 03:18 PM
Look for a RV dealer and call them tell them you want to flat tow a car behind an RV but the manual says that the vehicle is non flat-towable and do they have any external transmission pumps to correct this. That way you can find a local place that might have on and you could find out the price.
Joenavy85 06-30-2011 05:55 PM
I myself have done this, most RV Dealers will tell you to start the engine and place the Trans in Neutral in order to tow them.
d0sitmatr 07-01-2011 12:00 AM
what the others have said is about spot on.
the only other way to accomplish this would be a pump that turns with the wheels or driveshaft, but honestly that route might take a lot more work than a simply electric pump :)
katiep 07-01-2011 09:35 AM
but not all?
"Most," but what did any others say? Basically the same suggestions? I might try a phone call or two to see if the RV dealers near me will be helpful. Hmm!
99metro 07-01-2011 09:49 AM
I wouldn't EOC an automatic. Best to just neutral coast.
There are some that do successfully EOC with an automatic though. Not worth the risk or the hassle in my book.
