Old 05-07-2011, 05:41 PM   #1 (permalink)
JRMichler's Avatar
Nameless - '06 GMC Canyon
90 day: 37.45 mpg (US)
22 Maverick - '22 Ford Maverick XL
90 day: 42.77 mpg (US)
Fog light covers on an 06 Canyon
Just got another PM wanting to know how I did the fog light covers on my 06 Canyon. Photos are in my profile. Since the subject seems to be of general interest, here goes.
The fog light covers were inspired by an experience driving in heavy snowfall where the snow came down so fast that it filled the fog light holes, making the fogs unuseable. Any aerodynamic gains are small, but very welcome.
The Colorado/Canyon fog lights have a gap around them. That gap needs to be sealed before installing covers, or the area will be filled with dirt and salt glop thrown forward by the front tires. I sealed the gap with foam in a can, trimmed the bulging excess with a razor blade, and painted the foam surface black with a small paintbrush.
Start by making a template from a piece of cereal box or similar heavy paper. Cut a piece of acrylic (plexiglas) to fit the opening. This plastic is cheap and readily available (most hardware stores stock it), but very brittle. Saw very carefully with a new sharp fine tooth blade. Rough form to shape using a heat gun in one hand and a leather glove on the other hand.
Fasten the plastic in place using 3M body molding double stick tape (from auto parts store). Fine fit it by heating with a heat gun and pushing with a finger. A leather glove is needed. Be careful to direct the hot air on the plastic and away from the bumper fascia. When it fits all around, seal the edge with silicone sealant. Done.
The Following 3 Users Say Thank You to JRMichler For This Useful Post:
bertb (06-15-2011), Kodak (06-23-2011), mikeyjd (05-16-2014)
Old 06-15-2011, 11:54 PM   #2 (permalink)
bertb's Avatar
MoneyInMyPocket - '01 Honda Civic EX
90 day: 40.31 mpg (US)
BabysOdyssey - '05 Honda Odyssey
90 day: 20.96 mpg (US)
You've helped fill in the blanks on how to fit my plexiglas covers for the "air brakes" (holes) in my bumper.
Old 07-24-2011, 11:20 AM   #3 (permalink)
Kodak's Avatar
Canyon - '07 GMC Canyon 2wd regular cab
90 day: 24.95 mpg (US)
Hey JR, I know I'm bringing up an old thread, but I thought it'd be more useful to others than a PM.
Any pics of the backside of the fog lights (the gap where you put foam in a can)?
If you do, I'm curious how that came out. I've never used the stuff before. No trouble if you didn't take any shots from that angle.
EcoDriving: Turning more fuel into usable forward motion.
Old 07-24-2011, 11:44 AM   #4 (permalink)
JRMichler's Avatar
I don't have any pictures of the backside, mostly because you can't see much. The fog light has overlapping parts that hide the gaps and make it impossible to foam from the rear.
I foamed it from the front. Poke the foam tube in between the bumper fascia and the fog light lens, and foam away. Trim to fit, paint to hide, done.
Old 07-24-2011, 12:52 PM   #5 (permalink)
Kodak's Avatar
Ok, I can picture that now. Sounds simple enough.
Does this mod impact the ease of changing the bulbs?
Old 07-24-2011, 05:10 PM   #6 (permalink)
JRMichler's Avatar
It does not affect changing the light bulb. Unplug the wire connector, twist, and remove.
