Ethanol vs Ethanol FREE gas mpg?
Has anyone done an mpg average test between your typical gas and ethanol free gas on a modern car? I'm curious about the difference?
How modern is modern?
I ran a tank of E0 in my 2017 fuel injected motorcycle and saw a 3 mpg improvement (53-56), but the next e10 tank I got 61. I would say results inconclusive. The only e0 pump I've found is out of my way by about 5 miles so I don't think it would be worth it for anything I am actively driving (if its gonna sit I try and fill up with e0). |
lots of articles and the few rare tests ive found online say about a 10 percent mpg increase 60mpg in my ioniq getting boosted to 66mpg would be great with no work involved. the price difference isnt worth it obviously, but im curious just to see what type of high numbers i could achieve |
It's about a 3.5% difference, which is the difference in energy content. Most people see larger than 3.5% variance from one tank to the next, so anecdotal reports vary.
Difference in fuel consumption depends, due to higher octane number of ethanol - if engine management is advanced enough, it can adapt ignition timing and boost pressure to match those qualities. Watching only mpg numbers, it looks like gasoline is way to go, but if you care about fossile fuels burnt and carbon emissions, it's a different story. |
Long story short, after my aero mods, I want to fill up with ethanol free gas and try to squeeze 800 miles of range out on a single tank of gas for an experiment or YouTube video. In theory if I go even slower, I could do 900 miles from full to completely empty…
If you don't have a closer source there's the I-5 truck stop at Coburg, OR.
I just watched a video today, where it was tested and found that E10 87 pump gas being sold today, in the midwest, is actually 2-6% ethanol. It isn't anywhere near the "up to" figure.
Will adding nitro or noz boost my mpg too or just speed?
