Old 06-08-2012, 06:32 PM   #1 (permalink)
Sparky - '07 Toyota Prius Base
Voltage_kwh - '18 Chevy Volt LT
90 day: 151.04 mpg (US)
Voltage_gas - '18 Chevy Volt LT
90 day: 43.38 mpg (US)
Civic dash rattle(s)
Just wondering if anyone has any experience with dash rattles. Specifically I have a 94 VX. There was an existing rattle on the passenger side. I've had passengers try to put their hands on things to try to quiet it with no success. Now the drivers side is starting to make noise as well. It almost seems like the dash itself is loose. I suspect that having the tires "fully" inflated probably adds to it.
Old 06-13-2012, 12:58 PM   #2 (permalink)
Civic CX/HX - '97 Honda Civic CX/HX
90 day: 63.77 mpg (US)
Try taking out the dash and reinstalling. There might be something loose underneith.
Old 06-13-2012, 03:29 PM   #3 (permalink)
basjoos's Avatar
Aerocivic - '92 Honda Civic CX
Last 3: 70.54 mpg (US)
AerocivicLB - '92 Honda Civic CX
90 day: 55.14 mpg (US)
Camryglide - '20 Toyota Camry hybrid LE
90 day: 62.77 mpg (US)
Remove the glove box and look at the thin plastic members up in the space above the glove box. I had one of them crack so it made a buzzing sound when you ran the engine under load at low rpm. It was easy to fix with a spot of adhesive.
aerocivic.com
The Following User Says Thank You to basjoos For This Useful Post:
1carnut (06-13-2012)
Old 06-22-2012, 12:12 PM   #4 (permalink)
Just use it as an excuse to get rid of that blue interior and switch to black dash/interior!
Old 06-23-2012, 06:12 PM   #5 (permalink)
Always Too Busy
Flakbadger's Avatar
White Lightning - '17 Nissan Leaf SV
Team Leaf
90 day: 159.47 mpg (US)
Originally Posted by 1carnut View Post
Just wondering if anyone has any experience with dash rattles. [...] I suspect that having the tires "fully" inflated probably adds to it.
My dash has a few rattles. I solved two of them by stuffing a small strip of cloth in between the metal bracket and the plastic cover of the dash (had to remove a panel to get to them but no biggie).
Here in a couple days I'm going to remove the door panel and see what I can figure out about the one in there. I guess my advice would be, be persistent and don't be afraid to tear into it! Just make some notes of where all the pieces came from!
EDIT: I forgot, the high-PSI tires have a lot to do with it in my experience. When I first bought my car, the dealer had them at 28 PSI. When I bumped them to 40, the rattles began.
Nissan Leaf driver? Join me in Team Leaf and feel smugly superior about our MPGe
Current Car: White Lightning
Retired Car: Betty White
civic vx
