Old 05-07-2017, 07:22 PM   #1 (permalink)
Primer is still paint!
ChopStix's Avatar
90 day: 32.46 mpg (US)
Steel Braided Brake Hoses
So I wanted to upgrade my brakes on my 85 Chevy Pickup. I call Summit Racing and they sell me a Wilwood steel braided brake hose kit, among other brake parts. The kit comes in and obviously its high quality, but it only has the fronts, no rear brake hose. So I call tech support and they tell me that they do not show a rear brake hose and that I can use the steel hoses up front while using a rubber hose in the rear.
To me this sounds wrong as the stiffness differences between the hose types could possibly cause a brake bias issue. I'm envisioning the fronts locking up well before the rears in an emergency stop. Do you guys have any experience or opinions on this one?
Old 05-08-2017, 12:31 AM   #2 (permalink)
If you're on the brakes hard enough to tell you're either racing or doing it wrong.
Old 05-08-2017, 01:01 AM   #3 (permalink)
Braden steel tend to have less volume increase with pressure increase.
I have them on my firebird and it has the firmest feeling brakes I have ever encountered.
Old 05-08-2017, 01:53 AM   #4 (permalink)
What Frank said.
The only time I've ever actually needed the braided steel lines on my old car was on the track. And even there, all they did was keep my brake fluid from boiling over an extra few laps.
On the street, you will not have any problems at all, as long as you drive nice.
Old 05-08-2017, 02:09 AM   #5 (permalink)
ChopStix's Avatar
Thanks
I suppose I will try them as directed.
Old 05-08-2017, 03:10 AM   #6 (permalink)
ChopStix's Avatar
Most of this is common sense, but its interesting to see/read real world numbers for vehicle stopping distances.
nacto.org/docs/usdg/vehicle_stopping_distance_and_time_upenn
Old 05-08-2017, 06:37 AM   #7 (permalink)
one of thOOOse people
twitchy - '98 honda civic dx + sir + ls
90 day: 30.2 mpg (US)
Norman - '14 Ford E-350 EXT
90 day: 16.18 mpg (US)
Silver - '12 VW Golf Base
90 day: 26.1 mpg (US)
Sparta - '19 Honda CB300R
90 day: 84.07 mpg (US)
What they said.... And, your front brakes are suppose to lock first to help avoid over-steer and a spinout.
Old 05-08-2017, 10:32 AM   #8 (permalink)
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
AutoSpeed - Braided Brake Lines
TL;DR--the difference in hose expansion was 2.1% between old, worn rubber lines and new steel braided, and 1.4% between new rubber hose and steel braided, at pressures more than twice as high as a typical car's brake system can even produce.
UIUC Aerospace Engineering
www.amateuraerodynamics.com
