Old 04-06-2012, 10:41 AM   #1 (permalink)
hybrid using freon with Rankine cycle
cars have Air Conditioning, so the compressor is already mounted.
Add a couple of small Freon tanks. Heat one tank with coolant off the engine and exhaust.
Cool the other tank with cold water off the bottom of the radiator, or make it even simpler and use the evaporator on the front of the car.
When you want to go faster or accelerate, run freon into the front of the compressor, and use the compressor as a motor using the "hot" freon on the hot tank, with the waste going to the evaporator.
On decel, use the compressor to pump the liquid from the cold tank back into the hot tank.
Old 04-06-2012, 11:10 AM   #2 (permalink)
Drive less save more
ecomodded's Avatar
90 day: 60.42 mpg (US)
What are you hoping that will accomplish for you?
Save gas
Old 04-06-2012, 09:21 PM   #3 (permalink)
well, I can easily retrofit existing cars.
I can make a car into a hybrid for probably 400-800 bucks a car.
I can increase mileage in stop and go traffic.
I should realize 10 percent or so "free" mileage based upon typical Rankine cycle numbers.
Old 04-06-2012, 09:35 PM   #4 (permalink)
Diesel Addict/No Cure
cleanspeed1's Avatar
StolenHoopty - '90 Honda Accord EX
HvyDrnkr - '93 Cadillac Seville
Sounds strange. You MUST build it!
Volvo WIA42 VED-12 / 335 hp / 1300 ft/lbs / 9 mpg
Big n' Boxy, Never met a Hill it Didn't Like
