Experiment: coast down distances (rolling resistance) @ various tire pressures
1 Attachment(s)
The purpose of the test was to get an idea of the difference in coasting distances in my '98 Metro/Firefly over a range of tire pressures, 20-60 psi.
EDIT Jan 23/09: Posted a summary of this thread at: http://metrompg.com/posts/tire-press...resistance.htm Tire tested: 155/80/R13 Goodyear Invictas, rated 44 PSI max sidewall. EDIT - Also tested Oct 13, 2011... Bridgestone RE92 tires, multiple runs at pressures from 20-70 PSI. See this post: http://ecomodder.com/forum/showthrea...tml#post265379 Placard info: vehicle placard recommends 32 PSI front/rear @ max load. Pressure Gauge: readings were taken with an Accutire digital gauge, 5-99 PSI rated, with a manufacturer accuracy claim of +/- 1% + 0.5 Weather: 19C / 66F, 10 km/h SSW wind (roadway ran SW/NE) Methodology:
Ideally, I would have simply measured the coastdown distance from a constant speed at the same point on a level road, but my cruise control isn't working, and I didn't want to deal with the possibility of driver error (varying speeds). Even more ideally, I should have done multiple runs per pressure level. Since the car accelerates from rest and coasts to a stop, the differences in pressure are amplified compared to a simple coastdown test. Raw results for PSI/feet travelled 20 / 479.3 25 / 524.8 30 / 621.0 35 / 621.0 40 / 639.6 45 / 687.5 50 / 702.0 55 / 699.3 60 / 702.0 http://ecomodder.com/forum/attachmen...1&d=1212424018 http://metrompg.com/posts/photos/met...scale-1200.jpg |
Very good info!
Hello,
It is interesting to note that the plateau seems to happen roughly at the 44psi sidewall max pressure. |
Nice to see that 50psi seems to be the magic number ...
(You can tell the accuracy is questionable by the pair of identical distances at different pressures.) It's useful info as a "snapshot", but I wouldn't draw any hard & fast conclusions from it. Maybe it'll encourage other people to try it for their particular vehicles / tires. |
Cool Test :) How fast were you getting up to? I'm wondering if the air drag at the higher speeds is what is leveling off the results.
Not fast - 18.5 km/h @ 60 psi (the only time I checked).
But potentially approaching 28.5 km/h with the cross breeze (anyone want to do the vector calcs? :)), but the road was also partially sheltered by trees & buildings, so I doubt I was seeing the full wind reported at the weather station. I figure the varying breeze may have contributed to the pairs of matching results. |
Based on my aero+rr spreadsheet, at 10 mph (16 km/h), the proportion of power required to overcome rolling/mechanical vs. aero losses is: 0.44 to 0.05 hp.
At 15 mph (24 km/h) it's 0.74 hp vs. 0.16 hp for rolling/aero. |
Mehbe some more people will get out there and look for some data, but that's encouraging stuff, I think.
"Not really. Very good info would have been multiple runs at each pressure level to ensure I was getting accurate readings. "
You did do well, and deserve the credit. Very-very good info would be to either measure the temperature of the tire before and after each run, OR take an air tank with you and do the test again, but INCREASE the air pressure after each run. You might consider checking the tire pressure before you begin the run, and right after you finish, to see if there is a measureable difference. |
i may try it on my truck by using a scale to see what it takes to move my truck
Comp - that's not a bad idea. I guess a fish scale could work...
1 Attachment(s)
Here's more data. Same road, same conditions (except zero wind - it's blocked a ridge & buildings to the NW).
This time I did 2 runs per PSI, at a 10 PSI interval Car: 1999 Toyota Camry sedan V6 Tire info: 205/60/16 BF Goodrich Traction T/A, rated 44 PSI max sidewall. Placard info: vehicle placard recommends 32 PSI front/rear @ max load. Pressure Gauge: readings were taken with an Accutire digital gauge, 5-99 PSI rated, with a manufacturer accuracy claim of +/- 1% + 0.5 Weather: 20C / 68F, 4 kts N wind (NW sheltered roadway ran SW/NE) Methodology:
Raw results for PSI/feet travelled (1)/ feet travelled (2) / average 20 / 568 / 570 / 569 30 / 662 / 672 / 667 40 / 677 / 679 / 678 50 / 667 / 679 / 673 60 / 692 / 681 / 686 http://ecomodder.com/forum/attachmen...1&d=1212686195 |
What I find so interesting is the level of variation between runs, even with such a simple test.
Yeah the wobble in the graph for 50psi on an otherwise upward trend is weird, did anything unusual happen on the 667,50psi run?
Thanks for your commitment to real world testing... Always so interesting!!! |
It wasn't windy today - just a 4 knot, light breeze, and the road is very sheltered in that direction. I would have been more inclined to blame wind during the Metro runs the other day.
Nothing unusual happened that I noticed... |
for your next test,,,,,,,tire's at 50psi and alignment at 0 toe 0 chamber :D:D
Thanks for doing this Metro.
re: variance. Did you mark your starting position in two dimensions? Were there any variances in steering input maybe? Is there any reason to think that the brakes might not release evenly? |
I think it kind of interesting that the smaller tire there was a pretty big jump until about 45 psi while the bigger tire was at a lower pressure of around 35. I would of thought that it would of been the opposite.
On the starting hill, I moved into position each time by sighting down a wall beside me that was perpendicular to the roadway, and creeping the car until my line of sight was straight down the wall. Then I stopped completely and released the brakes when the coast was clear. Quote:
To put this into perspective for a metrompg.com post I'm working on (not up yet), here's the Firefly coasting results shown to scale:
click to zoom... http://metrompg.com/posts/photos/met...scale-1200.jpg |
Regarding Lazarus' post on the larger tire having less difference in distance per PSI level:
The larger tire has significantly stiffer sidewall area, which reduces rolling resistance. Obviously it's 40-60mm wider (manufacturer's measurements vary), but that may not win-over the loss of friction and warpage associated with tall/thin sidewalls. |
MetroMPG:
What pressure are you using for every day ? Thank you. |
50 ish.
distance
Darin,my thoughts are that if the car had been tested from some initial velocity,to a lower velocity,or stop,that you might have seen a greater spread in the data.Evidently,the starting force,which must be overcome just to get a car moving is remarkably high,compared to once its rolling.This is a reason for the traffic light synchronization,as "stops" eat a lot of energy.---------------- I think this effect is cutting into your numbers,although I realize the added complexity and variability of the coast-down.My suspicion is that your RR performance is actually much better than the numbers reflect.Your test does reflect a measurable effect so I say it's useful to all,kudos to you and !muchas gracias!,Phil.
I agree, a "normal" coastdown from some moving speed would have made for a better test, Phil. No argument there.
Thanks for posting and running the test. Has anyone had a blowout from running pressures exceeding the tirewall max?
where was there a report of a blowout because of extra psi?
Ideally you would want to conduct the test with the measuring device attached to the rear bumper rather than trying to hold it while trying to drive. Each time you pull the wheel to correct off coarse you add drag to the vehicle and affect the test results. I located a yourg man on you tube screen name=(landongendur)= that did some test with his metro. He took the mirrors off tested. He took the regular tires off and used 4 spare tires test vs regular. He ran vehicle with hatch back open test vs closed. He did speed test you name it if he thought of it he posted the results on youtube.
More inflation vs. rolling resistance data for the pile.
It matches the previous tests (meaning, rolling resistance decreases significantly up to a certain pressure, then plateaus). Tire tested: Bridgestone Potenza RE92 LRR tires in 165/65R14 size (Honda Insight OEM tire, installed on Geo Metro electric car - ForkenSwift) http://forkenswift.com/album/23-gt-w...re92-tires.jpg Weather: 25C, 8 km/h SW wind (test course ran NW/SE) Methodology:
http://forkenswift.com/album/8-chart...arious-psi.gif For kicks, see also: comparing RE92's @ 50 PSI to space saver spare tire donuts @ 70 psi - http://ecomodder.com/forum/general-e...donuts-70.html |
What's the rated tyre pressure for those tyres ?
Looks like there isn't very much to be gained by going beyond 40/50 psi |
44 PSI... and I agree, that's what it seems to show.
Are you going to try the reverse, 'normal' tyres on the insight ?
Nope!
I learned what I needed to learn from this test & the comparison of all the tires in the Suzukiclone fleet - RE92's at around 50 PSI are my best option for LRR. |
