EcoModder.com
-   Instrumentation (https://ecomodder.com/forum/instrumentation.html)
-   -   Expermintal FE meter, first pictures... (https://ecomodder.com/forum/showthread.php/expermintal-fe-meter-first-pictures-2252.html)
JohnnyGrey 05-10-2008 01:56 AM
3 Attachment(s)
This is the prototype of my DFM7 gauge. The display doesn't photograph very well in low light. Four buttons are soldered on the underside of the board: Left, Right, OK and Cancel. I've run a program on it already that does a good job displaying MPG on my specific vehicle, but now it's time to implement a complete menu system so that I don't need to reflash it to make adjustments. In addition to the typical trip and tank mpg/distance/fuel consumption numbers, I'm adding a historical average that doesn't reset when you fill up. This will be useful for calculating economy over long periods of time.
diesel_john 05-10-2008 09:44 AM
trip reset is the most important to me, as gas goes up, it means shorter tests.
SVOboy 05-10-2008 12:01 PM
Looks pretty good so far!
JohnnyGrey 05-10-2008 01:10 PM
Trip reset is accomplishied by holding down the left and right buttons simultaneously.
JohnnyGrey 05-22-2008 10:47 AM
Some more info...
MCU clock speed: 1.00 Mhz
Injector sampling rate: 125 Khz
Display refresh rate: 1.9hz
Display screens:
Trip A: Up to 65 gallons with 1/1000 gallon resolution, up to 655mi 1/100mi resolution
Trip B: Up to 6553 gallons with 1/10 gallon resolution, up to 65Kmi 1mi resolution
Tank: Same fuel resolution/range as Trip A. Any need for more than 655 miles?
PaleMelanesian 05-22-2008 01:08 PM
I've gone more than 655, twice. Is it a big deal to change that? I'd be fine with 1/10 mi instead of 1/100 for the tank. That's all my odometer gives me, anyway.
JohnnyGrey 05-22-2008 04:01 PM
Yes, I can do 6553 miles with 1/10 precision. Now does anyone have a tank exceeding 65 gallons?
rocket 05-27-2008 02:17 PM
are there any of these DIY gages (like this one) that are easy to create for thoes of us who are not circut/programing savy? I know basic circut stuff, basic soldering, etc but have never made anything like that. I'm more the mechanical kind of guy.
dcb 05-27-2008 03:24 PM
I don't know what JohnnyGrey's plans are with his device, he has only announced that it is not open source. But there are a number of people working on the open source mpguino . The goal of that project is to put fuel consumption feedback into as many hands as possible (read cheap and easy), so if you take a look and post over there about where we lost you then you would actually be helping too :)
http://www.ecomodder.com/forum/showthread.php?t=2115
rocket 05-29-2008 11:46 AM
Thanks dcb, i looked over that post and helping develp that stuff is out of my leage. I'll just have to be a leach and attempt to build it after its 'perfected' or just get a sgII
