Fender vents and Separation Traps
https://bimmertips.com/fender-vents-...s-the-purpose/
any thoughts on fender vents for the wheel wells? bmw uses them on the front and mercedes is even using them in the rear for their super low drag EQS https://cdn.motor1.com/images/mgl/9q...-rear-view.jpg also hyundai uses something called '' ''separation traps on both sides of the rear bumper '' for their new ioniq 6 which is also low drag, but they never specifiy exactly what they are or how they work. https://www.wardsauto.com/vehicles/a...ys-ioniq-6-bev anyone have any guesses on the rear separation traps? |
It's hard to offer an opinion when they never specifiy exactly what they are or how they work.
https://ecomodder.com/forum/member-f...55-scan-12.jpg Harry Bentley Bradley in 1981. |
It doesn't answer what is a 'separation trap' anyway. How does it differ from a Faschenfeld tearing edge [as seen on the new Prius]. It's in the bumper, is that them below the reflectors? Here's a properly designed front fender. https://ecomodder.com/forum/member-f...gt-one-ms5.jpg This one has a tight raidius, but massive venting on the top. https://ecomodder.com/forum/member-f...ry2012-sr1.jpg |
And you mean the Prius prime versus normal Prius? Where the led lights are? Isn’t it essentially just a super hard separation edge with like an inch mini box cavity essentially? |
thoughts on vents
You're looking at $100,000 in R&D to tune one of them. It's not for shade-tree aerodynamicists.
There are dozens of lower drag cars which never had them. |
The rest separation trap seems interesting though like what the Prius prime has too. Pretty much just a small partial box cavity. Which should be easy to fabricate |
how could it hurt?
Look at VMAN 455's website and Edgar's, or Edgar's book. If you were to arbitrarily open a pathway like that, you could easily see air flowing forwards through the breach, exactly what you're trying to avoid. It doesn't hurt BMW and Lexus and Mercedes to drop a few million dollars on CFD or wind tunnel time to 'dial-in' such small details. In this instance, you'd want to drop your money on the pizo ports, Tygon tubing, and Magnehelic so you could 'know' in advance if the IONIQ could produce rearwards-directed flow from the wheelhouse. It's not a given. Besides those openings need to be fully-skirted, something Mercedes wasn't willing to do, but would have had lower drag if they had. |
Time attack race cars vs a cutaway fender. |
