EcoModder.com
-   -   Filling Up Full Tank Adds Unnecessary Weight Thus Reduces Mpg. (https://ecomodder.com/forum/showthread.php/filling-up-full-tank-adds-unnecessary-weight-thus-2487.html)
dsq 05-22-2008 03:09 PM
GAS weighs 8lbs a gallon.
Weight reduces gas mileage.
So i would think it is best to drive with as little gas in the tank as possible.
LEts say you have a 12 gallon tank and fill up to full tank.That fuel weighs 96lbs...If you fill up with only 4 gallons youve just reduced your weight by 64lbs.
Thoughts?
ihatejoefitz 05-22-2008 03:22 PM
There is a point of diminishing returns because of the increased trips to the gas station.
MetroMPG 05-22-2008 03:52 PM
You could fill up, then siphon most of it out and keep it in jerry cans, adding it back to the tank as needed. :)
Sure, weight savings are good. The impact of removing 64 lbs will be very, very small (too small to detect in your fuel consumption log), but it's real.
Also, I thought gas was closer to 6 lbs per US gallon...
PaleMelanesian 05-22-2008 04:06 PM
1 Attachment(s)
Some of you have seen this before, or an earlier copy of it.
This is my daily commute, over the last 1.5 years. 500+ data points.
125% (above full on the gauge) and 1% (empty / low fuel light) both have 1/3 as many data points as the others.
My car stumbles / sputters a bit when it gets low, but still has fuel. I haven't run it dry yet. I may need to fix something there.
I have an 11 gallon tank.
Q3 is the 75th percentile, or halfway from average to max.
Q1 is the 25th, or halfway from average to min.
The linear portion (25%-125%) of the mean chart calculates out to about 0.5% decrease per gallon added.
http://forum.ecomodder.com/attachmen...0&d=1211486767
Attachment 780
dsq 05-22-2008 04:10 PM
yes you are right...it does weigh aprox 6lbs.
I thought it was the same as water.
http://www.santacruzpl.org/readyref/...gasoline.shtml
igo 05-22-2008 04:25 PM
That is a really interesting graph. You average over a 2 mpg increase riding with a 1/4 tank vs. a full tank. It makes sense but, it is cool to see a graph of the mpg.
Just seeing that graph makes me want to do some weight reduction.
ihatejoefitz 05-22-2008 05:03 PM
What can account for the drop from 25% -> 1% ?
PaleMelanesian 05-22-2008 05:15 PM
Updated the post above, but:
My car sputters and really doesn't want to start/restart when it's low. I do a lot more engine-on coasting and leave it running at stops instead of shutting down. There's still fuel available, but there's something it doesn't like. It's probably an issue with my car.
MetroMPG 05-22-2008 09:17 PM
I hadn't - thanks for reposting.
Any theory on why you're seeing such a large gain for such a small weight difference?
PaleMelanesian 05-22-2008 11:06 PM
I don't know. It shouldn't be that large a difference, but there it is. My strategy now is to run it low, but not quite to empty.
I did notice after filling up this morning, my glide points were off - rolling farther from the same starting speed. I do LOTS of P&G, so maybe the weight difference is more relevant there.
I like your idea of siphoning out gallons and then adding them back later. :D
