First Grill block design a failue.
1 Attachment(s)
So I tested a partial upper grill block yesterday. I'm not sure why but I actually got to watch my fuel gauge drop. One positive was my engine warmed up in less time, but it felt like it was working harder.
I compared the drive to my normal drive. Including coasting down hill and cruise control on flat roads. It felt like my car was being held back the entire time. I'm not sure what happened. I thought a grill block was suppose to have a positive effect, however minute, on driving. Any Ideas? |
Odd. Where dose the engine pull its air from? Did you inadvertently block the engine intake or cause it to pull hot air (not all cars like hot air mods).
Make another one, cover the entire grille/bow tie. It's winter, you shouldn't have any problems with overheating.
How many cylinders? Manual or automatic? How long does it usually take to warm up? Are you using a Scan Gauge? |
1.5 %
A fully-warmed car in mild weather with no wind over the exact same route would be required just to see this change through all the environmental 'bandwidth/signal-to-noise ratio. I suspect that you've reduced your drag a little,you just can't 'see' it. |
When i drove the car with the grille block the temp stablized at 195 where it typically stays. No fans came on. I'll try it without the block and see if anything changes. |
I'd suggest not looking to the grill block as a panacea. Some people seem to think that a grill block will make obvious improvements immediately, and that's a lot to ask of a little cardboard and tape. And basing "failure" on one day's driving just doesn't make sense.
Understand that it's not about "blocking the grill", it's about "improving aerodynamics". Cover the entire grill, and make it as smooth as possible, but know that modifying your driving habits will have a much bigger effect on fuel economy than a cardboard grill block, and you need to sustain any changes you make for longer than a day. |
That grille block looks sound, but as the other poster mentioned, you should probably block the entire upper section. No matter what, it certainly does not look like it's increasing drag.
Is there more grille below the bumper, too? If so, block 100% of the upper and a portion of the lower. I regularly see +/-10% variations in my fuel log for no reason that is immediately apparent. If you do coast-down testing including taking a video of your speedometer, you may be able to discern the effect of the grille block. |
Is there an opening below the bumper? If so, then I'd block off the entire upper grill.
Did you have a different wind on the test day? Was it colder? Maybe the handbrake was dragging, or a tire was low on air pressure? |
