Ford claims new 6spd increases FE up to 9%
1 Attachment(s)
Apparently they are using a 6 speed manual and a 6 speed automatic. The article only claims that the auto gets the 9% though. From the rest of the article though, the new Focus is shaping up to be a nice car.
http://ecomodder.com/forum/attachmen...1&d=1264594312 |
Now, if they give both the manual and the auto nice, tall gearing, and only off cruise (throttle?) control on the automatic!
The auto probably has an ECO setting in its software to change gears at lower rpm. If a normal auto had similar (many do), then that would give 2%-5% savings over "normal" mode.
...or, conversely, how about having the ECU provide driver-switchable "ECO" and "PWR" control settings over the transmission?
The "Automatic" is a computer shifted manual, thus the 9% savings and the term "power shift" being used to describe it. I've seen it and lust after it. It is also tiny and very light compated to any manual or automatic I've seen. I believe this was developed with a German company, I think Getrag?
Not surprising, Ford seems to be pointing their FE attempts toward their auto transmissions, especially in the Focii.. in fact, some auto Focii already get better FE than the manual versions on the highway. (EPA)
Gas Mileage of 2002 Ford Focus
The Wagon models reflect it in City mileage at the bottom of that chart. |
Tygen1 -
Any of us with a manual could still slay the automatic's FE around town. Steady-state highway cruising is where it may have an advantage. You can't beat the FE of engine-off, though!
Additionally it has a coast down feature that disengages the clutch to allow you to coast further with just a tap of the break, so theoretically you could put in a kill switch that kills the injectors and signals the computer that the brakes have been activated. EOC in an ATX !
