Old 10-13-2023, 06:17 AM   #1 (permalink)
Pinout for Dodge BSGs
So Dodge uses two different BSGs for its so-called etorque 2019-2022 Ram 1500:
  • 5.7L: P/N 68623194AA - Made by Magneti Marelli
  • 3.6L: P/N 05192387AD/68452771AA - Made by Continental
Does anyone know what their pins do, and perhaps where to get the connectors? No plans yet, just mental masturbation.
Old 10-13-2023, 10:17 AM   #2 (permalink)
Most vehicle oriented Haynes manuals have a mostly covered schematics, particularly between modules, internals, not so much.
Online doing a search for the unit will return manufacturers pinouts.
Sometimes Google is your friend.l, but you will be tracked and advertised to.
Old 11-07-2023, 11:22 AM   #3 (permalink)
So far my google-fu has been weak, hence me starting a thread here
Old 11-07-2023, 12:51 PM   #4 (permalink)
Eschew the Google
duckduckgo.com/?q=P%2FN+05192387AD%2F68452771AA+Continental&ia=we b
https://ecomodder.com › forum › showthread.php › pinout-dodge-bsgs-41142.html
Pinout for Dodge BSGs - Fuel Economy, Hypermiling, EcoModding News and ...
So Dodge uses two different BSGs for its so-called etorque 2019-2022 Ram 1500: 5.7L: P/N 68623194AA - Made by Magneti Marelli 3.6L: P/N 05192387AD/6845 Pinout for Dodge BSGs - Fuel Economy, Hypermiling, EcoModding News and Forum - EcoModder.com
Welcome to Continental AerospaceTechnologies' Factory New and Rebuilt Aircraft Engines › support › illustrated-parts-catalog.aspx
Illustrated Parts Catalog - Continental Aerospace Technologies
Select Model : Select a Model for Spec List Continental ® Jet-A engines Illustrated Parts Catalog and Titan™ engines Illustrated Parts Catalog coming soon. Boeing Distribution Master Distributor - Find the parts you need at a distributor near you Look up engine parts for each engine model
Welcome to Continental AerospaceTechnologies' Factory New and Rebuilt Aircraft Engines › account › parts-supersedure-history.aspx
Parts Supersedure History - Continental Aerospace Technologies
Parts Supersedure History The Part or Engine Supersede History section is provided for general information purposes only and is not intended to provide specific information concerning the use of any Continental Aerospace Technologies™ product.
Old 11-08-2023, 09:56 AM   #5 (permalink)
I watched a neat webinar on eTorque yesterday during lunch. The BSG integrates a PCM and inverter module.
Personally, I'd yank the inverter/HPCM out and just drive the phases with a VESC 75/300 or an openinverter.
Ran some simple calculations and the 5.7 HEMI BSG could theoretically pull ~275 amps, likely just in short bursts such as when spooling up the main engine. Even 200A continuous would likely let the smoke out.
