Ford testing cylinder deactivation with 1.0L turbo 3-cyl Ecoboost engine: 6% gain
1 Attachment(s)
http://ecomodder.com/forum/attachmen...1&d=1431545920
OK, you know things are getting serious when they start investigating cylinder deactivation in a triple. Ford says they've been doing on-road testing of rolling cylinder deactivation in their 1.0L turbo, with a series of countermeasures to manage NVH: Quote:
The "rolling" deactivation approach means each cylinder takes turns being the deactivated one. Quote:
And Ford: https://media.ford.com/content/fordm...enhancing.html |
hmm a modern hit and miss engine. :)
Put a big enough flywheel and muffler on it, and nobody'll be any the wiser!
I must say I'm surprised by the 6% figure. Seems high to me considering that 1.0L engine still wants higher engine load on a Focus even...
Every time I drive the T-Racer with it's 2.0L I think, "This car has waaaay too much engine"!
The 1.8L Civic gave me the same reaction. I have never said the same thing about the Firefly/Metro though!
With Metros I drop the "waaaay" but I think a 2-cyl Metro would suit me just fine; that is, if it gives me enough fe improvement.
Instead of making these damn cars harder to work on/diagnose, how about just more aerodynamic? That 6% will never pay for itself when it takes me an extra 2 hours to diagnose an engine misfire problem and I charge you 90$ an hour for labor.
Looks like greencarcongress has a comparison of fixed cylinder deactivation versus rolling deactivation on Fords 1 liter triple. NVH, complexity and cost balanced in the comparison. Looks like fixed is winning out in the cost and complexity without loosing too much gains in mpg. I'm not a fan of using dual mass flywheels because they fail often and at great cost in the used car market. They use them to help overcome the shakes.
