Old 05-03-2012, 11:49 PM   #1 (permalink)
itsnotme1988's Avatar
Saturn SL1 - '93 Saturn SL1
Last 3: 38.37 mpg (US)
Suzuki - '86 Suzuki Intruder VS750
90 day: 44.63 mpg (US)
Elantra GT - '05 Hyundai Elantra GT
90 day: 29.13 mpg (US)
Silverado HD - '11 Chevrolet 3500 HD
90 day: 11.87 mpg (US)
2008 Trailvoy - '08 Chevrolet Trailblazer LS
90 day: 14.96 mpg (US)
Ambie - '06 Ford Taurus SEL
90 day: 23.85 mpg (US)
Xj750j - '82 Yamaha Maxim XJ750
90 day: 32.47 mpg (US)
How does propane burn hotter with fewer BTU than gas?
Had this conversation with my brother today and everything I have found shows I was wrong and propane has a higher flame temperature than gasoline. Came up because he was talking about sweepers in the warehouse where he works ran much hotter than if they were gas powered. How is this possible? From what I have found 1 gallon of gasoline has 125000BTU and 1 gallon of propane has 91700BTU.
Old 05-04-2012, 12:00 AM   #2 (permalink)
Silver Bullet - '02 VW Golf TDi
Maybe it's because fuel in an ICE is metered by weight, not volume. Propane has about 22,000 btu/lb, whereas gasoline has about 17,5000 btu/lb. Or maybe it's because gasoline engines chill the incoming air charge through evaporative cooling, while propane is already vaporized before being mixed with the air.
Best tank ever: 72.1 mpg in February 2005, Seattle to S.F.
New personnal best 'all-city' tank June '08 ... 61.9 mpg!
Thanks to 'pulse-n-glide' technique.
Old 05-04-2012, 12:10 AM   #3 (permalink)
skyking's Avatar
90 day: 23.82 mpg (US)
90 day: 15.1 mpg (US)
90 day: 49.05 mpg (US)
Mule - '07 Dodge Ram 3500 ST
as stated above, use weight instead of volume. The most convenient method for me is Gallon Gas Equivalent (GGE)
Gasoline gallon equivalent - Wikipedia, the free encyclopedia
Look how diesel shows up there, far above any other common fuel. It does indeed contribute to approximately 10% of the economy difference between a petrol and a diesel engine. The rest is due to the better efficiency of the diesel cycle.
2003 TDI Beetle
2002 TDI Beetle
Custom cab, auto, 3.55 gears
Old 05-04-2012, 09:08 AM   #4 (permalink)
This is the year
Bug - '06 Volkswagen Beetle TDI PKG1
90 day: 37.04 mpg (US)
F-350 - '11 Ford F-350 Lariat
90 day: 16.23 mpg (US)
A bit technical, but the diesel cycle isn't more efficient than the otto cycle. Diesel engines are more efficient because of increased compression ratio's.
Old 05-04-2012, 09:43 AM   #5 (permalink)
mechman600's Avatar
Fusion - '16 Ford Fusion Hybrid SE
+ less pumping losses because of no throttle plate
+ more energy content in fuel
Old 05-04-2012, 09:50 AM   #6 (permalink)
This is the year
Compression ratio is the dominant factor for thermal efficiency, but those factors help.
Old 05-04-2012, 09:54 AM   #7 (permalink)
There is a better explanation of diesel versus gasoline engines here.
Old 05-04-2012, 12:49 PM   #8 (permalink)
Phantom's Avatar
Blue Meanie - '02 Volkswagon Golf TDI
90 day: 48.52 mpg (US)
Wife's car - '05 WV Passat TDI
Rudy - '94 Chevy C2500
I think most of the reason is the air fuel ratio gasoline is 14.7lbs of air to 1lb of gas and propane is 15.67 to 1 so propane is burning one more pound of air.
I move at the speed of awesome.
"It's not rocket surgery!" -MetroMPG
