EcoModder.com
-   Aerodynamics (https://ecomodder.com/forum/aerodynamics.html)
-   -   Front air dam vs underbody belly pan (https://ecomodder.com/forum/showthread.php/front-air-dam-vs-underbody-belly-pan-39636.html)
67-ls1 08-15-2021 12:01 PM
2 Attachment(s)
On an old car, in my case a 1966 Chevelle, with a horrendously shaped underbody, is it better to use an air dam to try to keep the air out or try to fab a belly pan?
I already have an air dam I’ve made for the front so would it be worth it to remove it and smooth the underbody?
The Chevelle is a full framed car with dual exhaust the full length, two relatively huge mufflers, I live rear axle. It’s a mess. It would require a LOT of framing to support it and I’d still have to leave the exhaust area open.
This is more for mpg than downforce.
Opinions?
freebeard 08-15-2021 12:53 PM
Most people seem to use the air dam because it's less fabricobbling.
If you do a belly pan start at the front instead of the back (or so I hear).
IRONICK 08-16-2021 02:41 AM
'Front air dam' cannot even be compared to 'underbody belly pan'.
It is a percentage of what 'underbody belly pan' can do.
67-ls1 08-16-2021 03:45 AM
So your vote is for a belly pan. Noted.
freebeard 08-16-2021 01:11 PM
ecomodder.com/forum/showthread.php/aerocivic-how-drop-your-cd-0-31-0-a-290.html
The Aerocivic has dual side skirts between the wheels.
elhigh 08-16-2021 04:41 PM
I think the general consensus, arrived at in other threads on this very topic, was that a good front air dam could deliver about 70-80% of the results of a comprehensive belly pan at 10% of the cost and effort. If you already have a dam built the obviously start there. Establish some baseline results without the dam for comparison, then run some tanks with to see how it fares.
Add the side skirts a la Aerocivic and it likely gets even better.
67-ls1 08-17-2021 09:55 AM
Very interesting. 70-80% of the results is a pretty good return considering how much easier it is.
freebeard 08-17-2021 02:06 PM
That's why they're more popular. Bang for the buck.
aerohead 08-18-2021 11:20 AM
Chevelle
Opinions?
GM's two lowest drag cars had full belly pans and no front airdam. Cd 0.137 and Cd 0.14 ( if we ignore the Cd 0.089 Sunraycer ).
A 'guess' for the '66 would be around Cd 0.51.
Today's 'Chevelle' Malibu is around Cd 0.28.
A look under a modern Malibu would say a great deal about GM's strategy for drag reduction over the decades.
HOT ROD Magazine used a full aluminum belly pan on their Cd 0.20, 200-mph Project Red Hat Camaro ( originally around Cd 0.49 ).
There are no low-drag cars without full belly pans.
You're the only one who can make the call on, how much you're willing to invest, time and moneywise.
In one example of a early- 1980s Cd 0.30 car, a full pan with 'slow' diffuser netted a delta- Cd 0.070 drag reduction.
67-ls1 08-20-2021 08:42 PM
I agree with everything you say. But a belly pan on a old full frame car would be a huge undertaking. So I’ll have to live with the less efficient airdam for now.
