Old 10-11-2011, 02:32 AM   #1 (permalink)
schematic tool?
what tool do most of you use for drawing up new schematics? preferably something with some built in footprints, but also the capability of being able to draw new footprints. doesn't have to be able to simulate things, i just want something for drawing the schematic.
thanks!
Old 10-11-2011, 03:41 PM   #2 (permalink)
JasonG's Avatar
05 DMax - '05 Chevrolet 2500HD
90 day: 18.48 mpg (US)
I use Simplis/Simetrix
I believe it is free.
Simple paste and click interface.
Once you get used to it, it simulates very well except for pump-charge circuits.
It comes with some basic examples.
I reccommend "save as" from the samples until you learn how to set up a simulation.
I can't understand why my MPG's are so low..........
21,000lb, 41' Toy Haulers are rough on FE!
The Following User Says Thank You to JasonG For This Useful Post:
isaac_alaska (10-11-2011)
Old 10-11-2011, 09:00 PM   #3 (permalink)
sid
grayranger - '10 Ford Ranger XL 2 door supercab
90 day: 31.78 mpg (US)
I use LTSpice, which is SPICE simulation software that is free from the IC manufacturer Linear Technology. An example schematic that I did may be found at http://www.stonemarmot.com/images/AK9a.jpg. The full article is at stonemarmot.com/rants » AK-9 Low Power Guitar Amplifier. You should be able to search the net to find the software.
2010 Ford Ranger, extra cab, 2.3 liter
Band's latest song/music video "I Sing Along"
Old 10-11-2011, 09:35 PM   #4 (permalink)
Thanks guys! I actually figured out how to edit the part footprints in orcad pspice. So now my fuses don't cover half a page. Il try out these other programs though too
Old 10-12-2011, 04:44 PM   #5 (permalink)
...beats walking...
...If you're REALLY inventive, you just use MS Excel's object templates.
Old 10-12-2011, 06:46 PM   #6 (permalink)
haha...i've never used that before but it sounds like what i was imagining lmao. i'll check it out!
Old 10-12-2011, 08:11 PM   #7 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
A lot of hobbiests use eagle by cadsoft. Limitations when mapping a schematic to a pcb on the free version, top and bottom layers only, 80 x 100mm max, not a problem for many projects. Not a limitation for schematics, only when doing a pcb layout.
http://www.physics.utoronto.ca/~astu...e_CadSoft.html
