Full set of Potenza RE92 R14 - Toronto Area
4 bridgestone potenza re92, 175 65 14, good tred
If anyone from this area is coming down to the green grand prix, PLEASE buy these and I will pay you for them + more for your trouble. Even if you don't bring them down, there's 4 re92's for real cheap on CL for you. I want these >.< |
The ad says 175/65/14 ... didn't the gen 1 Insights come with 165's?
Don't question it, go get them! I don't expect anything from CL ads until I at least talk to the poster, but especially until I see the item(s). Snatch that gravy up before someone else does.
R U CRAZEE? I'm not driving around with an unnecessary 20 cm of tire width!
(But I emailed the seller to confirm size) Have you posted on insightcentral.net? Seems like that would be the best place to look for the gen 1 165's. |
I usually dont post here, because I'm on insightcentral.net.
but the 165/65/14 RE92 are special and are LRR. They are also lighter and made of harder rubbers. They are actually even lighter than the 13" version of the RE92. So any other size other than 165/65/14 is not the special LRR Tires originally made for the Insight. The 165/65/14" version weigh only 13lbs There 3 versions of the 175/65/14. Weighing 16 and 15lbs. These were used on the Prius, Yaris and Echo. |
I figured this crosspost would be appreciated. An Insight owner is selling his 11000mi RE92's: Tires again?? - Page 3 - Insight Central: Honda Insight Forum
